Old 07-18-2007, 11:11 AM   #1
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
First dent blues
I found a 1950's 3" pipe clothesline pole with my endcap.
I need to have my butt-tachometer recalibrated - had been shifting trailers all morning using 4X4 low range and had my spotter busy mowing beneath trailer while it was pulled forward when this happened.
I saw if I moved trailer a bit more the lawn would be neater so I hopped in F-150 and started it up and dropped it into gear - the motor was on high-idle and covered ALOT more ground creeping forward then it had all morning.
Opinions on lower panel ripples? It was one of the good corners too..
ID:	41412   Click image for larger version
Old 07-18-2007, 11:20 AM   #2
Replacement will make the quarter panel ok again.
Old 07-18-2007, 11:36 AM   #3
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Sorry, aluminum stretches when it bends/dents. Not too much to be done. On the other hand, it doesn't look toooo bad.
Family of Disney Fanatics
WBCCI# 4821
Old 07-18-2007, 02:28 PM   #4
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Smile
I had similar damage and I put a new piece over the damage. It was not hard. Made a templit to catch the curvature and cut out the new piece with a jig saw
ID:	41431   Click image for larger version
ID:	41433   Click image for larger version
Pop Rivet is offline   Reply With Quote
Old 07-19-2007, 07:01 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Don't you have a parts trailer that you could rob a skin from?
Aerowood is online now   Reply With Quote
Old 07-19-2007, 09:29 AM   #6
SLVRSRFR's Avatar
Orange city , Florida
Send a message via AIM to SLVRSRFR
Ouch! Just performed the same oops a few weeks ago on my sovereign. except on the front. Its a good 5 inch dent. (nailed it while backing semi trailer) best of luck with the repair!
SLVRSRFR is offline   Reply With Quote
Old 07-19-2007, 09:56 AM   #7
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Just tell anyone who asks that it was caused by a Bandit attack in Sri Lanka and that your under orders from the State dept. and can't say anymore about it.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 07-19-2007, 10:42 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Unfortunate, but polish it off, and go camping.
SuEllyn & Brian McCabe
Old 07-19-2007, 11:20 AM   #9
SLVRSRFR's Avatar
nice one "Goin campin"
Old 07-20-2007, 09:39 AM   #10
Wabbiteer's Avatar
1972 29' Ambassador
*Thanks Andy, prompt and cheerful as always....
*Minnie's Mate, always helpful, thanks...
*SLVRSRSR - yup, stuff happens...
*Goin Campin - neither confirm or deny...
*Moosetags - salvage trailer panel is in worse shape..
*Pop Rivet, nice pictures & even better repair, since this hit is easily accesible from interior it'd be panel change out, if it gets repaired at all, as it is sooo shallow wrinkling..
I believe this will get the dry-ice & heat gun treatment; found cans of chewing-gum remover for $2 on clearance yesterday so will try an aerosol cold source before moving to the CO2 block to try and quench the stretch out..
The gentle embrace of aluminum yielding against an immovable object starts off so faintly it never registered that I could be striking something. I don't think I had a chance to stop before the trailer snubbed hard against it but now that sensation has been recorded in the "wet ware" in the things to avoid department. Keep alert folks, just a errant second of inattentiveness is all it takes...
<doh!>
Old 07-21-2007, 07:00 AM   #11
Aerowood's Avatar
Arvada , Colorado
I had good luck removing a large gouge on my GT using the tool shown on post 65 of my "skin corrosion" thread. It was easy to make and works better then I expected.
Old 07-21-2007, 07:27 AM   #12
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I have a LOT of bumps and bangs on the '51. At first it bothered me but now I look at it and realize that it still looks an awful lot better than I do and we are almost the same age. So the obvious ones that were fix-able without a ton of work and expense I've taken care of and the others are reminders that this trailer gets used - it's not a driveway queen.
Ah well, it would be nice though to have the body of the twin to mine I found for my buddies. One or two little things on the outside to deal with and theirs is virtually dent free - where on mine I think there's one panel that doesn't have a dent in it, I just haven't found that panel yet.
Take pictures to share of your repair efforts and heck, if it ends up having some markings, but doesn't leak or cause a safety issue, put your shades on, gas up the truck, and go camping.
Barry
safari57 is offline   Reply With Quote
Old 07-21-2007, 09:37 AM   #13
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
Self-inflicted wounds are the worst - the ones where there is no one to rant about except the guy in the mirror ..... I have several of those - small and inconsequential so far ..... but the downfall of Airstream longevity is that the odds eventually catch up .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
Underbelly Blues hex Belly Pans & Banana Wraps 3 10-24-2002 08:47 PM
Polishing Blues. TBKP's Overlander Cleaning, Stripping & Polishing 19 10-12-2002 07:57 AM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
