Old 10-04-2008, 07:25 AM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Filiform - only newer trailers or older too?
I have been reading the posts about filiform here in the forum. I still can't get my hands around what years are effected. It seems like it is mostly newer trailers, perhaps after '00 or '01 or later. Is that right? I know I have read a couple of posts or blogs where a few older / vintage trailers were effected, but it does not seem as prevalent. Is that correct? Does it have to do with the coatings used by the factory to protect the skin? I understand they have changed over the years.
We are thinking about a late '90s Excella, I thought the worst thing I would have to deal with is the headliner, but is filiform going to be an issue too? Depending on how the economy goes have also been thinking about an early current decade model with the newer interiors.
Curious also, on the vintage units where they polish the surface, is filiform still an issue. Also curious, if AS was to paint the units similar to a car, would this problem decrease?
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 10-04-2008, 07:38 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Filiform is going to occur on any aluminum product where the protective coating is compromised and something to cause the corrosion sets in. I have seen it on aluminum architectural sheet metal where someone screwed up and put decorative copper above it. I think most of it on Airstreams is caused by rock dings micro cracking the surface of the coatings or Alclad and then having what ever getting into the actual aluminum and having it's way. It can also sometimes result from electrolysis, caused by improper electrical grounds and corrosion on electrical connections to the shell.
Here is a link to a paper dealing with it.
Edit: Missed the part about trailer age... I have seen it from the 70's foward. I think it is less prevalent on the trailers from the 50's and early 60's they were not coated.
Aaron
WBCCI #XXXX AIR #2495
Old 10-04-2008, 08:47 AM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's not just found on newer trailers. Our '74 has some, in a couple locations. Our trailer has spent most of its life near either the Atlantic Ocean or the Gulf of Mexico.
Old 10-04-2008, 09:29 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Though I would agree that any alum product has the potential to corrode, it would seem to me that steps could be taken to prevent or at the very least minimize the effects.
Taking only newer model Airstreams from the linked thread below, a legitimate question is how can new units, some as young as 6 months old see such widespread symptoms? I wish I had more answers and frankly, had I known this was going to be such an issue, I may have opted to buy a used one that already had taken some depreciation hit, rather than pay top dollar for a new unit. I love my Airstream, just very unhappy with both the overall quality of the build (a whole different thread) and the corrosion issue. Both issues, IMHO could be resolved for future new units rolling down the line, but oddly enough, QC issues elude Airstream and frankly the industry as a whole.
http://www.airforums.com/forums/f142...ams-31743.html
http://www.airforums.com/forums/f142...ity-41668.html
Old 10-04-2008, 09:42 AM   #5
Well Preserved
1993 21' Sovereign
Eric, I talked about this a few months back, but I am comparing this situation to when the Big 3 auto makers got poor quality steel in the early to mid 1970's. This resulted in many cars rusting away to junk in less than a year. I can only hope the aluminum maufacturers will "fix" he problem soon.
Old 10-04-2008, 10:23 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
The flipside to this question would be, "By what age would I expect clearcoat on all airstreams to be degraded?" Perhaps there would be some agreement on 10 years +/- for units stored outside.
The issue Silvertwinkie has always raised is why the heck these problems happen on trailers so new.
Walbernize is the old product and there have been countless posts about products that offer better protection. An example searchword that will take you to some of these threads is Meguiars. Pull up a stool; this will take some reading. FYI our search function is only useful with one word in the search field.
5 meter Langford Nahanni
Old 10-04-2008, 10:33 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
I think it is actually faster than that, and it will depend on the local environment and how the owner took care of the trailer. I checked in to the possibillity of redoing the clear coat on my 1975. At the time I was quoted over $5000 and it probably wouldn't last more than 5-7 years before needing to be at least partially reworked. Painting it with an aircraft quality paint job was approximately the same price. But even those don't last forever.
For the time being I have allowed mine to acquire a gentle patina quite often referred to as APB (Airstream Pattern Baldness)
If and when I ever win the Megamillions Lottery I may reconsider my decision...
Aaron
Old 10-04-2008, 11:26 AM   #8
I win Megamillions and I'll tool down the road in the Airstream president's parting gift...
Old 10-04-2008, 12:32 PM   #9
_
Originally Posted by Soyboy View Post
...if AS was to paint the units similar to a car, would this problem decrease?
hi soyboy...
the DID paint'em one year.
and some folks have older units painted once the plasti-kote peels...
YES paint last much longer, but there may still be places with filiform corrosion under the paint...
it is just not VISIBLE, until the paint lifts, peels or fails, after 10-20 years.
i agree with wahoonc on this, EVERY 'stream ever built is subject to CORROSION.
forget the filiform issue, that's primarily the 'type' of corrosion happening on newer CLEARCOATED units...
but they all can corrode and often NOT on the surface, but deeper and in structural places.
imo the use of mag and cal chloride in winter road salting and dust control on un paved roads is the issue...
steel and automobile bits exposed to these new road salts are EATEN quickly....
we are now seeing this with aluminum things too.
i've seen vintage units and new trailers being dissolved by these road salts...
it's amazing really.
cheers
2air'
Old 10-04-2008, 12:40 PM   #10
Aluminut
2004 25' Safari
. , Illinois
I can say without question, my unit spends most of it's time in a somewhat climate controlled garage. Dehumidifier on in the garage (not that it needs it really), and my unit is washed and Walbernized 2x per year. Never any salt, not near the ocean and have never taken the unit within 3-4 states of an ocean. The exterior is so clean you could eat off of it. I never let sap or bugs stay on long. My unit is well maintained, yet what started now has grown. You can see my first pics posted at the beginning of the corrosion thread at:
Airstream Issue
It's my understanding that the skins and the wheels are Alcoa. I am on my second set of rims and cast tail lights, which are in the photos...these were replaced in spring of 2005 at only about a year and a half old. The pictures of the rims and tail lights were two years old from the replacement date and I can assure you, even though the pics don't look as bad as some, in a little over a year since those 4/07 pics, the issue has grown.
My interior CCD like skins are beautiful, of course, they are not on the outside.....
Old 10-04-2008, 01:04 PM   #11
_
Originally Posted by Silvertwinkie View Post
the wheels are Alcoa...
not true, unless u have now have classic 5 spoke wheels that were discontinued in 2006.
cheers
2air'
Old 10-05-2008, 10:36 AM   #12
Soyboy's Avatar
1999 28' Excella
Images: 44
Silvertwinkie: It's a major bummer what you and others have been going through. I would be upset too. In this day and age there ought to be a way of preventing or at least delaying this problem for a longer time. I still kind of lean towards painting as it seems to work on cars and trucks for 10-15 years or more. Houses have alum siding on them (RVs too) that lasts for years and still looks good (well.....in a way . Why not on these trailers?
2airishuman: I still don't understand why the new units seem more inclined to have this problem. When I read the other threads, it seems that the newer units, over maybe the past 5 or 6 years are pretty much the only ones being discussed. I know that it does happen to more vintage units, but it does not seem to come up as much. Maybe it's just that owner's of the newer units are upset after spending the big bucks and then having this problem. Or is it the current "treatment" they are using on the trailers? Seems like the "treatment"/protective coating should get better over years that the trailers are built, not worse.
As to wheels, I have Alco wheels on my Dmax and they look like new after 5 years and my truck spent the first 3 years of it's life in Michigan with all of the salt and snow. Why can AS use a similar quality product on their trailers. Same with the light housings etc.
It almost seems like the best thing to do (as others have said) is purchase a used trailer where you can see how it is holding up and which has already taken the major depreciation hit (my plan). Plus, if you are ambitious and have the time, maybe polishing it is the route to go, then you can "keep after it" on a seasonal basis when you to the necessary re-polishing. But that is only if you are in to Airstreaming the way other folks are into hotrods. Some folks are into Airstreaming as more of the RV/Camping thing and have no interest into putting that effort/money into the trailer.
Me, I kind of strattle that line which makes the decisions more difficult. I have always wanted an AS and now I am considering scratching the "itch" likely with a mid to late 90's Classic or Excella with the ceiling falling down (but that's another issue). If not I'll likely go the Bigfoot or Arctic Fox route (maybe a used Sunline). But they have their issues too. It amazes me that most of the folks that have these problems still love their AS and woudl still purchase another one.
Oh yeah, when I hit the Lotto, it will be a Newell or Prevost. I'll worry about getting into the smaller campgrounds later . Maybe I'll purchase a new AS International and a nice new diesel for those times when I want to "rough" it. After all, lots of folks on here have muliple trailers and kind of do the same thing!
Thanks for the input!
1999 28' Safari
TAC MD-6
AIR 4534
Nuclear Reactor Corrosion versus Airstream Filiform Ray Eklund Ribs, Skins & Rivets 0 06-08-2008 12:56 PM
Filiform Corrosion? Harper Ribs, Skins & Rivets 7 06-08-2008 10:45 AM
Filiform corrosion Brad Hunt Ribs, Skins & Rivets 4 11-19-2007 12:17 PM
Small MH: Older Airstream v. newer SOB Jan Airstream Motorhome Forums 11 10-19-2003 08:58 PM
The newer models have different engines. TBKP's Overlander Our Community 0 04-10-2003 07:33 PM
