Old 11-19-2007, 08:04 AM   #1
2007 25' Safari SS SE
Alton , Illinois
Filiform corrosion
I have been reading about this corrosion on a thread. I understand it exists but what is it exactly. Is this a surface cosmetic issue only or will it lead to structural problems?
The "Ann Rutledge"
Brad Hunt is offline   Reply With Quote
Old 11-19-2007, 09:21 AM   #2
_
hi brad
here is a short definition of filiform or wormtrack corrosion, note it is spelled with one el...
Filiform Corrosion
here is a link to the article mshwarz provided in the other thread (post 35)
JCSE Volume 2 Paper 36
and a large searchable site on corrosion, including filiform...
Corrosionsource.com - The One-Stop Materials and Corrosion Information Resource
in most situations (ours) it is a cosmetic issue...
cheers
2air'
Old 11-19-2007, 11:38 AM   #3
2002 19' Bambi
Lafayette , California
2air has provided very good information. I would like to emphasize that the coating that filiform corrosion burrows under can be pigmented paint. In such a case, the corrosion is usually not noticable unless it is very extensive. Our Airstreams make such corrosion apparent because of the clearcoat. Not only is the corrosion visible, but its contrast with the surrounding non-corroded aluminum is very obvious.
The corrosion on non-coated aluminum parts is almost never if not never filiform.
Tim A. is offline   Reply With Quote
Old 11-19-2007, 11:55 AM   #4
84Sovereign's Avatar
1984 27' Sovereign
Escondido , California
We have plenty of this, but our clearcoat is trashed anyway. We plan on polishing our AS and hope this will help.
Chris
84Sovereign is offline   Reply With Quote
Old 11-19-2007, 12:17 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
At first it is just an annoyance, but left alone for a long enough time can cause structural problems
Corrosion offleash Ribs, Skins & Rivets 5 01-04-2008 08:07 PM
Aluminum Corrosion dbaur Cleaning, Stripping & Polishing 2 10-06-2007 09:30 AM
Segment Protector Corrosion chaunceyboy Ribs, Skins & Rivets 27 06-14-2007 07:05 PM
Corrosion Zugbug Ribs, Skins & Rivets 7 07-06-2006 05:16 PM
Need help with corrosion SAMCPA Ribs, Skins & Rivets 8 04-28-2006 09:14 PM
