Old 04-05-2009, 10:23 AM   #15
Images: 59
Those were explosive rivets, used for repairs back when your trailer was still a baby. You can't buy them anymore. I found a few near a repaired area in my '59.
The hollow backside was filled with a small charge. When you heated the top, the back end blew out and formed a nice upset.
Old 04-05-2009, 10:37 AM   #16
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by InsideOut View Post
Could they be "Cherry Max" or more specifically "Cherry Q" rivets?
Shari
Shari is right on the money here, I haven't seen these since the 70's. The name as I remember them are "self plugging friction lock blind rivets" they are made by both Cherry, and Olympic, and we called then "Oly"s. They are not considered a structural rivet. They install the same as the Olympic rivets used on repair of Airstreams today. The stem breaks off and require shaving. If you could replace them with solids you would be better off.
Kip
Old 04-05-2009, 10:55 AM   #17
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Oh Lee.. I feel your pain! If you need help drilling them out... give me a call! I might be buying a compressor and rivet gun sometime.... so if you want, I'd share.
Marc
Old 04-05-2009, 11:16 AM   #18
Originally Posted by silverleeper View Post
These are covering the curb side. I don't think it's a repair job. Most of the skin on the trailer would have been replaced then!?! The rivets appear to be solid on the outside. If they are pop rivets what type are they?
Those rivets are the old "explosive" type.
They have been history for at least 35 years.
They were the "approved" method of sheet metal repairs, back then.
Old 04-05-2009, 12:33 PM   #19
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Thanks again, I was hoping for better news. Crap!!! So, I think I need to by stock in a rivet company.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-05-2009, 12:36 PM   #20
If you have some explosive rivets that are loose, simply buck them a little, and that fixes the problem.
Old 04-05-2009, 02:09 PM   #21
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
I had a 58 overlander that had the whole side replaced with those explosive rivets. It was not noticeable from the outside but after removing the interior panels it was obivious that the whole side was replaced. Every one of them were loose and leaking. I wish I had thought of bucking them to tightening them up.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 04-05-2009, 04:19 PM   #22
2001 19' Bambi
Falmouth , Massachusetts
explosive rivet video on youtube
An interesting view of how these work(ed)...
Marshall Swartz
2001 19-ft Bambi
2013 Honda Ridgeline RTL
mswartz is offline   Reply With Quote
Old 04-05-2009, 05:39 PM   #23
Explosive rivets were installed using a 350 to 500 watt soldering iron, that had a tip that matched the brazier head of the rivet.
You had to apply a little pressure in order for the heat to quickly transfer.
That was the cause of loose fitting rivets, since that pressure cause the metal seams to push inward, especially on segments, unless you were very careful.
Old 04-05-2009, 08:56 PM   #24
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
They don't look like CherryMax to me. That rivet has a bulb on the bottom of the pull stem that fills in the hole in the back side of the rivet when it's pulled. Also, the pull stem is visible on the head of the rivet where it breaks off. I can't see any evidence of a pull stem on the heads in the photos.
Way back there was an "exploding rivet" that was installed in the hole and then heated with a soldering iron to cause the rivet to expand below the sheet metal. I've never seen these installed, but remember seeing ads for them in the aviation publications back in the 60's.
mimiandrews is online now   Reply With Quote
Old 04-17-2009, 11:59 AM   #25
1967 22' Safari
1960 Caravel
Images: 8
Thanks Andy, You can buck these rivets. Before-After...
ID:	78628   Click image for larger version
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 04-17-2009, 04:44 PM   #26
navyeod's Avatar
1958 26' Overlander
1991 29' Excella
auburn , Alabama
Wow
I knew my navy training would come in handy someday. Sure has been a long wait. I thought you guys were kidding about explosive rivets.
navyeod is offline   Reply With Quote
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Used A/S from the factory ? brunoffrance Buyer Guidelines 8 01-19-2009 09:29 PM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
