Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-03-2003, 06:25 PM   #29
dinoburb
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Rivet Tools
Rivet installation tools are reasonably priced and, with practice, produce an excellent product. (make double sure the air riveter is a real rivet tool not an air chisel) I believe the reason most owners, and probably many repair facilities choose Olympic rivets is the reduced manhours necessary to complete most repairs.
With a true 'bucked' rivet full access to both sides of the rivet is required. This generally means the interior must be removed to repair any exterior items. That level of disassembly is not generally required with Olympic 'blind' rivets. Simple one-side access is the prime requirement.
There are better blind rivets available which will do a superb job of repairing the A/S aluminum, however, the tools necessary to install are cost prohibitave. Huck and Cherry are rivet brands that make high strength, aluminum binding rivets suitable for any A/S repair. Their cost and the cost of the tools put them in the professional category. Olympic, on the other hand, is owner installable, low cost, effective, and, with the shaver tool, nearly impossible to tell from bucked rivets.
If the facroty is doing the repair let 'em buck the rivets, if you're doing the job, become an Olympic champion and shave after every installation!
If you want to see some alternative tools (and sources of aluminum) and rivets click on this: http://www.wicksaircraft.com/ or this: http://www.aircraftspruce.com/
Hope this helps. 20 years of flying and maintaining Navy Aircraft as well as constructing two experimental aircraft have given me plenty of time to learn the trade.
Take care,
Sean
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 09-03-2003, 07:07 PM   #30
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
Shari and all - here's a photo of a just shaved Olympic rivet. Notice the black circle is missing. Once this is hit with the polish, it will look great. When shaving Olympics, trim them until the circle is gone. Take your time and you'll get a great looking factory look alike.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 09-03-2003, 08:20 PM   #31
markdoane
Profile:  , Minnesota
Images: 59
Rivets
Dinoburb: thanks for the input. I have two nephews, one West Pointer and one Annapolis (still active duty). Go Navy.
Old 09-04-2003, 03:43 AM   #32
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
flyfisherman -- your shaved rivet looks great! Maybe you should give lessons to the Airstream factory staff as their Olympic rivet installations leave the telltale rivet-stem circle!
yukionna is offline   Reply With Quote
Old 09-08-2003, 04:41 AM   #33
yukionna
yukionna's Avatar
Images: 18
Here's a photo of the damaged panel...
Name:	2003-08-30 peeling finish 1.jpg
Olympic rivet removal and installation PeterH-79MH Ribs, Skins & Rivets 38 08-13-2008 02:31 PM
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Factory visit dtbw On The Road... 1 11-01-2003 02:43 AM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
