Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-22-2017, 07:10 AM   #1
V Pline's Avatar
1962 19' Globetrotter
DeWitt , Michigan
Exterior Patch for 1961 Overlander
We removed the heater from our 1961 and want to cover the opening. We are wondering what type of aluminum to use? We have an extra panel from an interior repair (paint on one side but bare aluminum on the inside) and wondered if that was the same type of aluminum used for the exterior... OR do we need to order material? Where would you recommend ordering from? Type, model, etc. THANKS!!!
V Pline is offline   Reply With Quote
Old 02-22-2017, 07:13 PM   #2
V Pline's Avatar
DeWitt , Michigan
Wondering if it will "shine" and/or polish like the exterior...
Old 02-22-2017, 09:01 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi there. I did a Google search for patches in the forum and I'm hoping the link below takes you to several threads that may help. I'm not sure what material you'd need but you may find it in one of these threads. Good luck!
https://www.google.com/search?q=show...&bih=628&dpr=2
Old 02-23-2017, 02:35 AM   #4
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
2024T3 aircraft aluminum 0.032" thickness is what Airstream used for the exterior in those early years. Aircraft Spruce and Specialty Company is one source.
Old 02-23-2017, 07:28 AM   #5
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
In the 60s the interior aluminum was the same as the exterior. Give it a polish and you will see.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
To patch or not to patch... truckirwin Repairing/Replacing Floor &/or Frame 8 05-01-2014 05:18 AM
1961 Bambi :: 1961 novus1 Airstream Registry Discussions 0 05-22-2012 06:53 PM
Body mods: To patch, or not to patch? Belegedhel Ribs, Skins & Rivets 0 01-05-2012 09:33 AM
1961 BAMBI :: 1961 Airstream BAMBI DUNSKI Airstream Registry Discussions 0 08-19-2011 08:31 AM
interior skin scrap for exterior skin patch? whatsherface Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
