Old 10-19-2003, 09:20 AM   #1
Mariner's Avatar
Exterior panel repairs and replacement
Hi all,
I am going to be looking at a '78 Airstream on Tuesday. From the photographs already emailed to me, there is a sizeable dent in one of the front panels - approx. 2 - 3 ft up from the turn of the floor to the wall.
Can this dent - I won't call it a crease as I cannot see a line, be removed without major work? If not, how involved would it be to replace the panel? Does the interior shell need to disturbed to repair the outer shell?
Sorry about what might be a dumb question. I need to know before going and looking - especially if I am going to be talking prices. I may not buy it, then I might be quite smitten. Just need to know in advance.
Thanks in advance, to any and all comments.
Mariner
Mariner
1987 Avion 34V travel trailer (the other cigar tube).
2002 Dodge CTD 3500 Dually, Auto, 4x4
1986 F250 T/C 6.9 Diesel, LB,S/C,4x4,Auto
Mariner is offline   Reply With Quote
Old 10-19-2003, 09:48 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Dent
Mariner,
Some dents can simply be pulled out with a suction device, others need more attention.
If panel replacement is necessary, then it depends on which panel it is that has the damage.
Side panels are vey long, and therefore somewhat more expensive than the smaller panels. In most cases you do not need to disturb the interior, as far as I know. I was quoted $ 1500.00 to replace one of my side panels, which runs the entire length of the trailer on the street side.
I would not like having extra seams, and just replace the damaged area, butthat is a possibility also.
Make sure the dent is not where there is a rib behind it. If the rib is bent, then you should be able to see it in the interior. I imagine this would be a lot more work and expens than a dent between the ribs.
yoiu can tell where there is a rib by the vertical rivet lines.
Good luck!
Uwe
www.area63productions.com
Window screen replacement smallfry Windows & Screens 15 04-30-2004 03:15 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
Repairs on the road ( Or on the shoulder ) thenewkid64 Mechanics Corner - Engines, Transmission & More... 5 05-19-2003 09:22 PM
