Old 07-21-2015, 10:08 PM   #1
Dunedin , Florida
Exterior dents caused from the inside
I hope this is the right place to post this....Me and my husband are totally renovating a 1973 Avion camper. I mean we ripped out the wiring and insulation and all. We've never done anything like this before and we are already starting to see the results of our rookie mistakes. While we were taking out the foam insulation we were using the back of hammers to claw out the insulation not realizing we were creating dents that now show through on the outside. There are no actually holes, just a bench of dents on the exterior. Is there ANY way we can smooth out those dents? Please be easy on me, we are totally clueless!
Ardygurly is offline   Reply With Quote
Old 07-21-2015, 10:15 PM   #2
1979 23' Safari
Wayland , New York
You can try a dent roller, it looks like this,
Lock Technology Shaping Tool Attachment for Pry Bar - Dent Roller Part# LT790
Out of stock there but look around on the internet.
A little masking tape over the dents to prevent scratching.
How many dents are we talking here?
Old 07-21-2015, 10:23 PM   #3
1979 23' Safari
Wayland , New York
Seems out of stock most places, these guys seem to have them,
SHAPE TIP TOOL LT790 | Matco Tools
Old 07-22-2015, 06:23 AM   #4
Dunedin , Florida
sadly we are talking dents across the whole entire camper
Old 07-22-2015, 06:25 AM   #5
Dunedin , Florida
thank you guys for the idea though. I'll for sure look into those rollers
Old 07-22-2015, 10:57 AM   #6
Mission Viejo , California
Try to contact a metal smith or artisan near you. They will be familiar with the tendencies of metals to stretch and likely will have the tools and skills to remove the dents.
Or, if the dents seem similar to hailstone damage, a craftsman with hail repair skills could be valuable.
If you attempt to repair wrongly you could damage the panels even worse. Stretched metal is not easy to put back in shape.
Bill Lynch is offline   Reply With Quote
Old 07-22-2015, 12:38 PM   #7
1967 26' Overlander
Spartanburg , South Carolina
There was recently a thread that described using suction cups on the outside to pull dents out apparently with very good results. A little more research on Air Forum should get you to that information.
Jacob D is offline   Reply With Quote
Old 07-22-2015, 11:11 PM   #8
San Antonio , Texas
Dents
Why would you remove the insulation?, but since you have I would find a person who knows how to work aluminum, probably an aircraft sheet metal worker (NOT CHEAP) I have a couple of little dents (from outside) on my 78 28J AVION but even as an aircraft mechanic I would not tackle them.
Good luck
PS We have had our AVION camping in Colorado in temps as low as 0 deg. F and stayed nice and warm, thats what the foam insulation is for.
Ralph12 is offline   Reply With Quote
Old 07-24-2015, 06:26 AM   #9
Dunedin , Florida
Good luck
we removed the insulation because the wiring was bad and there were leaks and holes throughout the camper so we wanted to strip it down bare to redo the whole thing. We plan to put new foam insulation in . I'm going to try the roller just to see how that goes. The dents are cosmetic so I think hiring an aircraft sheet metal worker is out of the question. That just sounds expensive lol
Old 07-24-2015, 11:27 AM   #10
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Send me a PM
Old 07-24-2015, 01:37 PM   #11
Aerowood's Avatar
Arvada , Colorado
I meant to saw "send me a pm regarding dent rollers"
What Caused This on 2011? ncbambi 2009-2015 Flying Cloud 26 06-15-2011 06:04 PM
Shiny Trailer Caused Fire Lucky 13 Cleaning, Stripping & Polishing 11 09-12-2010 06:55 PM
Vibration caused by the highway gil Morris Member Introductions 18 05-29-2006 05:36 PM
Changes that caused some errors... Andy R Forum Admin, News and Member Account Info 0 08-28-2004 05:48 PM
Urgent: frame damage caused by improper jacking? Rog0525 1969-1971 Caravel 39 03-31-2004 05:35 PM
