Old 07-31-2011, 09:37 AM   #1
Spaceliner
douglasbury's Avatar
1961 22' Spaceliner
Delavan , Illinois
English Wheel
Part of my plan to restore my airstream involved buying an English wheel. I picked up one from HF to practice on. Bought some aluminum and did a decent job shaping a 12 x 24 inch piece, when held against one of the more complex end caps it laid perfectly flat. My plan is to use over sized pieces and once the form is correct cut the panel to size. The one thing I didnít like about the process is the marks the wheel leaves on the aluminum. Does anyone have experience or advice that might help me?
Doug
douglasbury is offline   Reply With Quote
Old 07-31-2011, 11:03 AM   #2
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
You might be using too much pressure? But I think that you're always likely to get SOME marks. This probably depends in part upon a) the amount of wheel pressure used, b) the smoothness of the upper and lower wheels, and c) operator experience. My only experience with English Wheel or planishing, involved steel ... and since I was a novice, I left some marks. When finished, I simply used 1200 and finer grit silicon carbide cloth and then the usual finer and finer grades of polishing compound to get rid of any marks. But again, that was not aluminum ... admire your self-reliant attitude. Good luck!
AirsDream is offline   Reply With Quote
Old 07-31-2011, 11:50 AM   #3
Spaceliner
1961 22' Spaceliner
Delavan , Illinois
Englich Wheel
Thanks, I will try it with less pressure. I did spend about an hour polishing the wheels before I used them.
Old 07-31-2011, 12:16 PM   #4
Sound fun!
Can you post some pics of your progress, as I would love to have a go too!
Old 08-01-2011, 02:23 PM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Your biggest problem is the Harbor Freight English wheel. I have used the HF with less then stellar results as the bottom anvil has a tendency to move around a bit. Maybe if you could take some off the play out of the bottom adjustment screw and lower anvil holder it would work better. I have used a professional grade unit and the results were greatly improved
Old 08-01-2011, 04:20 PM   #6
Splitrock's Avatar
Sioux Falls , South Dakota
Video of Jesse James making aluminum gas tank shows him annealing, beating the shape on a shot bag, rolling, and smoothing on a pneumatic hammer.
Old 10-28-2011, 09:20 AM   #7
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Great video
Thanks for posting the video.
desertair27 is offline   Reply With Quote
Old 09-07-2015, 01:21 PM   #8
English wheels stretch metal, only.
I have never heard of them shrinking metal.
Please correct me if I am wrong.
Old 09-07-2015, 02:46 PM   #9
Mission , Texas
I haven't done it on an AS, but here is a video example of how to do it (not me).
nrgtrakr is offline   Reply With Quote
Old 09-07-2015, 02:50 PM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
After only 4 years, another thread rises from the dead...
FYI, "English" was the inventor's name, not so much his heritage.
Old 11-25-2015, 08:04 PM   #11
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Perhaps it should be raised from the dead.
An English wheel can also polish. That is the technique to remove small dents in the exterior skin. Folks have tried other dent removers while the skin is still on the trailer, this method requires the skin to be removed.
It would be much easier to polish the damaged skin to true than to make a new one.
Even though polishing with low pressure will remove dents it should not stretch the skin. Every dent removal case will be unique. Saving one panel, will pay for the machine, saving two panels will be money ahead. Process time per panel, around 30 minutes.
Lastly will the panels be returned to new condition? No they will not, presentable yes.
sgschwend is offline   Reply With Quote
english wheel, exterior skin
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
Tow vehicle wheel base flynmike Tow Vehicles 15 05-09-2011 08:27 PM
wheel for 67 eubank Wheels, Hubs & Bearings 5 03-06-2011 03:39 PM
