Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 04-20-2014, 07:33 PM   #1
DWH
1961 22' Spaceliner
Clinton , Washington
Endcaps for a '61
Does anyone know if the endcaps on the 1961 models are formed or not? I need to replace a couple pieces in a corner and haven't pulled the original ones off yet. I'm just wondering if I can cut the new aluminum and fit it in place or if I need to take the old piece with some new aluminum to a fabricator to match the shape.
Thanks!
-Dale
DWH is offline   Reply With Quote
Old 04-20-2014, 07:54 PM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Dale,
If you don't see any rivets of segments then your endcaps are fiberglass. If you see rivets or segments then they are aluminum. Your age trailer should be fiberglass. 1960 and newer trailers are 99% fiberglass endcaps except for Bambi, Since Spaceliner is rarer than others you might be apart of the 1%?1
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 04-20-2014, 08:10 PM   #3
DWH
1961 22' Spaceliner
Thanks for the quick reply. It looks and feels like aluminum to me. Someone at some point had painted the top white. Here is a picture one of the endcaps.
-Dale
Old 04-21-2014, 06:02 AM   #4
asbury park , New Jersey
Your exterior endcaps are aluminum. They are formed.
NJtoNC is offline   Reply With Quote
Old 04-21-2014, 06:10 AM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Thanks!
The end cap segments are aluminum. These segments are obsolete, however depending on the degree of damage, they can be repaired using assorted metal shaping tool. I recently repaired two rear end cap panels on a 65 Overlander, & most would be hard pressed to figure out which panels were repaired.
Colin
Colin H is offline   Reply With Quote
Old 04-21-2014, 09:39 AM   #6
DWH
1961 22' Spaceliner
That's what I figured. Thanks for the assistance!
-Dale
Old 04-21-2014, 10:31 AM   #7
Most all of those segments (end caps) are still available.
Andy Rogozinski
Inland RV Center
Corona, CA
'59 fiberglass endcaps 1959newbie 1954 - 1959 Overlander 14 12-14-2006 07:26 AM
Replacing Argosy MH galvanized endcaps. . . TheGanzman Argosy Motorhomes 6 09-30-2005 05:32 PM
Weird aluminum on endcaps? silvrtwinkie Ribs, Skins & Rivets 4 05-16-2005 12:41 AM
new member - endcaps and frame? ed moller All Argosy Trailers 5 01-06-2005 07:16 PM
wood endcaps inside? Dave Cole Upholstery, Blinds, Walls & Interior Finishes 1 11-01-2002 02:32 PM
