Old 04-29-2010, 02:51 PM   #1
Emergency skin corrosion info please!
I've read tons on the forum about skin corrosion but need some emergency advice on how to save my 72 Tradewind.
A previous owner had replaced the "Tradewind" side, trim plates with two that had been molded by another source other than Airstream.
The metal used in the trim plates caused an extreme bi-metallic corrosion issue underneath the plates until they actually fell off the trailer when the rivets actually corroded through. Underneath the
trim plates, there had developed SEVERE intergranular, skin corrosion.
As the trailer is in a coastal evironment as well,....what can I spray or apply to these two areas to keep them from completely rotting through??
Now that the trim pieces are no no longer attached, will a coating of LPS-3 or something provide ANY emergency solution to stopping the corrosion in those spots.....??
HELP....
yochanan is offline   Reply With Quote
Old 04-29-2010, 03:04 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
There is only one way to truly stop intergranular corrosion and that is to remove the cancer per say. LPS3 is indeed a good water displacement agent but it would be to little to late. Your only permanent fix is to cut it out and scab on an external repair, or if you are real handy with metal work, the installation of an internal doubler with a flush filler installed with flush rivets, or replace the entire skin. Sorry
Kip
Old 04-29-2010, 03:30 PM   #3
Kevin245's Avatar
It sounds like galvanic corrosion (reaction). This is an undesirable side effect that can occur when metals of differing nobility are in contact with each other. The metal of lower nobility will experience galvanic corrosion. Basically becoming a sacrificial anode of sorts. The desired AI Index in a harsh condition such as a coastal area should be less than 0.15V where possible.
If the damage is severe then Kip's suggestions are probably your only options.
Kevin
Eleanor Roosevelt
corrosion, emergency, skin repair
emergency brakes PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 8 08-06-2012 06:02 AM
Emergency help needed! markdoane Batteries, Univolts, Converters & Inverters 10 06-22-2007 08:11 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Emergency Winterize!? sarmimi Winter Living 27 10-16-2005 08:02 PM
Emergency parts Bill Resseau Mechanics Corner - Engines, Transmission & More... 11 04-23-2003 09:21 PM
