Old 02-20-2014, 08:32 PM   #1
copycat carl's Avatar
1957 22' Flying Cloud
1963 28' Ambassador
Gadsden , Alabama
Electric metal shear.
I am in the market for a hand held electric shear. Does anyone have a suggestion on which one to buy? I am working on a 63 Ambassador. Thanks!
copycat carl is offline   Reply With Quote
Old 02-20-2014, 08:45 PM   #2
2007 27' Safari FB SE
Olympic Peninsula , WA
Hard to beat a KETT shear. You can usually find a used one on Ebay for $30 or less; about the same price as a Chinese knockoff. If you were closer, I'd loan you mine.
DoubleNickel is offline   Reply With Quote
Old 02-20-2014, 09:08 PM   #3
1963 28' Ambassador
Gadsden , Alabama
Thanks for the help. Is there any particular model that I should look for? I saw a new Kett 440 on amazon but it was rather pricey.
Old 02-20-2014, 10:36 PM   #4
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Although I'm loathe to admit it, I purchased one of the Chinese knock offs at Harbor Freight. So far it's worked pretty well.
DryFly is offline   Reply With Quote
Old 02-20-2014, 11:08 PM   #5
If you're only going to use it for one project, the HF model would be OK- you're only cutting light gauge aluminum...look for the 20-25% off coupons they post in nearly every magazine you can think of...
If you want a better one, there are quite a few Milwaukees on eBay right now. Usually there are quite a few Kett's listed-(but they look pretty sparse right now) I actually ended up with 2 at ~$30 each a couple of years ago when I got ahead of myself and had two bids out simultaneously... Gave one to a friend.
metal shear in Tools | eBay
Old 02-21-2014, 05:09 AM   #6
1973 25' Tradewind
Augusta , Georgia
I have the 18 gauge shear from Harbor Freight. Only real complaint is that due to foot design, it is very awkward to use with a guide to get a perfectly straight cut. This is more operator inability than tool limitation. For <$40 and low volume needs it's hard to bet. Also You can usually find 20-50% off coupons in mail or online.
18 Gauge Sheet Metal Shear
DGJackson is offline   Reply With Quote
Old 02-21-2014, 06:09 AM   #7
aquinob's Avatar
Portsmouth , Virginia
I got the HF shear last year, its a serviceable tool, good for occasional cuts on aluminum sheet metal. It worked for what I needed it to do, just keep some oil on the blades when you cut and take your time. Practice on some scrap if you can to perfect your technique.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 02-21-2014, 06:32 AM   #8
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I purchased one at the local hardware store for $110. I noticed the head design looked very similar on the expensive Milwaukee tool compared to my cheaper one. I wanted one where I could rotate the head in relationship to the handle so I could get into awkward places. Mine looks like a 3/8" drill driving the shearing head. Mine has worked great and met my expectations.
David
Old 02-21-2014, 07:04 AM   #9
1971 27' Overlander
Jackson , Tennessee
Two cents?
I'm glad others have had better experiences with HF tools, but my shear made it through all of 4ft of 0.25 sheet before the innards turned into a handful of pot metal crumbs. I guess it's just a roll of the dice
Nothing quite like a well-made tool, and I can look forward to giving the good ones to my three sons.
Alan
TennTex is offline   Reply With Quote
Old 02-21-2014, 08:49 AM   #10
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
If you have a decent sized air compressor, I would suggest looking at the air-driven shears as opposed to the electric ones. No doubt, the electric ones are convenient, but you can't beat pneumatic tools for safety when working around freshly cut metal with sharp edges, and you run the risk of skinning an electrical cord.
Old 02-26-2014, 08:08 PM   #11
1963 28' Ambassador
Gadsden , Alabama
Thanks for all of the replies to my post. I have been bidding on used sheers but I have not "won" yet.
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
Adding Electric Heater to Atwood ElliotA Water Heaters, Filters & Pumps 4 05-19-2013 01:53 AM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
