Old 04-13-2010, 01:26 PM   #1
Arlington , Virginia
Dumb question regarding belly pan..
I have a 24' 1979 Argosy Minuet that I'm rebuilding. I found a leak and traced it to the connection between the belly pan and the lower side segment of aluminum. Once I removed the track for the belt insert, I noticed that the belly pan wraps up and over the top of the lower side segment. This strikes me as an obvius place for water to attack a seam and cause a leak, which is exactly what's happened. Lapping the seam the other way would permit the water to simply roll off, like two roof shingles. Was this trailer assembled wrong? Has any one else ever noticed this connection?
gonorthwest is offline   Reply With Quote
Old 04-13-2010, 01:32 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
From what I have read here that is the norm.Just put some good sealer on the seam. Dave
easyride is offline   Reply With Quote
Old 04-13-2010, 02:34 PM   #3
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
It's the way the 76 Argosy 22 is built, since the body is lowered onto the frame, guess it was easier to overlap the body pan rather than tuck it under the shell. A bead of sealer on the top of the beltline moulding will cure it.
arcamedies is offline   Reply With Quote
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly pan material question SilverHoot Belly Pans & Banana Wraps 2 02-08-2010 12:59 PM
Belly Pan Rivet question Gregg S Ribs, Skins & Rivets 1 09-01-2009 08:30 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
Can you help? Water in belly pan question Eddy General Repair Forum 5 07-04-2007 06:10 PM
