Old 09-16-2010, 07:34 AM   #1
1971 21' Globetrotter
Hebron , Kentucky
Drilling out Rivets
I am doing some Aluminum repair on the outside of my 71 Globetrotter and having trouble drilling out the olympic rivets. My main problem is keeping the bit centered on the head without slipping to one side. Is there a tool for keeping the drill bit centered?
GaryO is offline   Reply With Quote
Old 09-16-2010, 07:43 AM   #2
x
XXXX , XXXX
Use a center punch and a hammer to indent the head of the rivet. this will keep the drill bit centered on the rivet head. Use a variable speed drill and start off slowly until bit has begun to bite into the rivet. Unless the panel has been repaired before the rivets will not be Olympic rivets just regular buck rivets. Driil into the rivet only far enough to go the depth of the rivet head. then use the center punch to snap off the head and push the shaft of the rivet into the trailer.
wasagachris is offline   Reply With Quote
Old 09-16-2010, 07:46 AM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you will look at the aircraft supply house, most sell drill guides for drilling out rivets. Would not want to put a hole in the side of a nice King Air by the drill slipping.
Aircraft Spruce-http://www.aircraftspruce.com/catalog/topages/rivetremoval.php
Avery Tools- Avery Tools LP - RIVET REMOVAL TOOL
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 09-16-2010, 07:48 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
And here for a little less money....
Rivet Removal Tool
Old 09-16-2010, 08:19 AM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
I do some of this but not a lot -- hasn't been worth it for me to order something job-specific. I hollow grind the top of the rivet a bit with a Dremel and then use a standard twist drill. Seems to be quite reliable...
5 meter Langford Nahanni
Old 09-16-2010, 09:40 AM   #6
1968 20' Globetrotter
Kelowna , British Columbia
I've been using a push type center punch...no need for a hammer...and it works well. Make sure both the punch and drill bit are sharp and be gentle when starting the drill.
Canlib is offline   Reply With Quote
Old 09-16-2010, 09:57 AM   #7
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Spend the $40.00 for the Rivet Removal Tool. I got one and it makes drilling out rivets a breeze. It's quick, easy and does a perfect job.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 09-16-2010, 10:08 AM   #8
Aerowood's Avatar
Arvada , Colorado
Using a drill with at least 3000 RPM helps along with the proper drill bits. Use of 135 degree split tip cobalt drill bits is the best.
Old 09-16-2010, 10:17 AM   #9
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Follow this link here for a great Rivet Removal Tool. I highly recommend it.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
drilling Lexan? pinkflamingoes Windows & Screens 28 01-05-2013 06:43 AM
drilling out rivets dhe9 Ribs, Skins & Rivets 9 02-08-2006 12:07 AM
Drilling out rivets MarkR Ribs, Skins & Rivets 5 06-12-2005 09:54 AM
Drilling out rivets... Andy R Ribs, Skins & Rivets 24 04-19-2005 11:36 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
