Old 10-01-2005, 02:26 PM   #1
Send a message via Yahoo to dhe9
drilling out rivets
have a rivet head broken off. my question is should i use a 5/32 drill bit and how deep should i drill? the rivet is on the outside.
i have ordered olympic rivets and vulkem sealent and am just waiting on your knowledge.
david
socal
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
dhe9 is offline   Reply With Quote
Old 10-01-2005, 04:09 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Wait until you get your new rivets, then measure the outside diameter of the new rivet's shank to determine the bit size. Drill just until the bit makes it way through the old rivet's remains (quarter-inch or so).
Got a rivet shaver to finish the head?
Tom
p.s. 32 years -
Old 10-01-2005, 04:45 PM   #3
don't have the shaver yet but as i only have the one rivet missing i will use the demmrel tool that home depot sells.
how does one measure the diameter of the shank? is the shank the part that goes into the rivet gun or the part that goes into the trailer?
32
30 active & 2 reserve. retired 6 years and 30 pounds ago.
'03 19' bambi
2011 CTD DIESEL
SEMPER FI
RETIRED USMC
Old 10-01-2005, 04:58 PM   #4
TomW's Avatar
1967 26' Overlander
The part that goes into your Airstream
Tom
Old 01-27-2006, 11:18 PM   #5
Johndigbydog's Avatar
1966 22' Safari
Eagle Lake / Eastport , Florida / Maine
Anyone out there used the rivet shaver that Vintage Trailer Supply sells for $199? How many rivets can it shave before it becomes dull? Thanks
Johndigbydog is offline   Reply With Quote
Old 01-28-2006, 08:41 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Lightbulb
Gotta say this is one place where Inland Andy has a good no-brainer. Go to http://www.inlandrv.com/parts/ and scroll down to the part number below.
79015 view part Drill Bit Kit 3 - #30, 2 - #21, 1 - #11 (stubby) per kit $7.95
The 3 smallest are for 1/8" pop-rivets -- multiple uses on interior and exterior. The 2 mid-size drills are for 5/32" and Olympics. The good thing about this set is they are short twist drills -- if the rivet pushes in suddenly (as will happen!) you can't poke through to the opposite skin!
I've found it difficult to stay on top of a round rivet to start drilling it out unless I dimple the top with a Dremel first. And with a Dremel I can use fine grinding stones and rubber polishing wheels to smooth the rivet -- saves the shaver cost, though a critic could look closely and probably tell the difference. My polishers are pretty standard dental lab stock.
5 meter Langford Nahanni
Old 02-04-2006, 07:21 PM   #7
1966 22' Safari
Has ANYONE used the rivet shaver that Vintage Trailer Supply sells for $199
(ONE MORE POST ON THIS QUESTION) HOPEFULLY AN APPROPRIATE ANSWER.......... John
Old 02-04-2006, 07:47 PM   #8
Tinsel Loaf's Avatar
YES, from Vintage Trailer Supply . It has not worn out yet. Let the tool do the work. Don't force it and it will last a long long while.
Tinsel Loaf is offline   Reply With Quote
Old 02-04-2006, 08:30 PM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Me, too. What Tinsel said, plus the fact that the tool is of excellent quality, and does a very fine job of trimming the rivet to look just like a bucked rivet.
Uwe
www.area63productions.com
Old 02-08-2006, 12:07 AM   #10
1966 22' Safari
Thanks for the replies, Now I can feel confident ordering one for $199. John
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
