Old 10-26-2015, 07:03 AM   #1
Bullit's Avatar
1971 18' Caravel
Nokesville , Virginia
Double exterior skin???
Has anyone seen doubled exterior skins. I removed my banana wrap on the front curbside and found both the lower and mid skin is doubled. Click image for larger version
Name:	ImageUploadedByAirstream Forums1445864549.636259.jpg
You can see the bottom edge in this photo and I noticed the skin was doubled when I removed the scare light
Bullit is offline   Reply With Quote
Old 10-26-2015, 07:34 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
The interesting part of this picture is that there is no row of bucked rivets in the outer layer of skin holding the shell to the C-channel. My guess would be that this is a repair job where instead of removing and replacing the damaged segment, they just overlaid the replacement. They probably just slipped it in behind the lower trim without even removing the trim, and therefore, the lower rivet line was never exposed.
good luck!
Old 10-27-2015, 01:29 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
This has been seen many times before, basically who ever did these repairs was looking for the cheap and easy way to repair the damaged panel. Do you plan on fixing this?
Old 10-28-2015, 07:32 AM   #4
Bullit's Avatar
1971 18' Caravel
Would like to replace lower skin. It appears to not have a significant arch and not too difficult to replace. Would wait till the frame has been replace.
How is your trailer going?
Old 10-28-2015, 09:03 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The lazy and cheaper way of Airstream shell repair. Makes one wonder what is hidden underneath.
MICHAEL
Old 10-28-2015, 09:12 AM   #6
Belegedhel's Avatar
Houston , Texas
All of the perimeter segments that form the front end are formed aluminum. Herein lies the challenge of replacement. You basically have to either buy a new one from the dealer, in which case it won't be the same alloy as your original, or find a used one from a donor trailer. Either way, expect to pay about $500 for the part and the shipping. If your exterior segments (that cover the first layer) are in good shape, then I would suggest that you take the assembly apart, remove the under-layer, and then buck in the outside layer properly.
good luck!
Old 10-28-2015, 10:03 AM   #7
Bullit's Avatar
1971 18' Caravel
I would like to replace the lower panel??? May have to leave them all in place if it's going to be major Pain. The quality of work leaving Ohio in 1971 is astounding. The c channel below this panel was cut about 2 inches short and contributed to a great deal of floor rot. Frame and floor must be sorted out first
Old 10-30-2015, 07:01 AM   #8
Aerowood's Avatar
Arvada , Colorado
I have felt your pain, I was surprised to find all of the quality gone on mine to. See my thread below on my 71
Old 10-31-2015, 06:24 PM   #9
Bullit's Avatar
1971 18' Caravel
Aerowood , I have read your posts and re-read many of them. You continue to be a major source of inspiration. The body came off today and I am beginning striping and assessing the frame.
Name:	ImageUploadedByAirstream Forums1446337466.832970.jpg
The double skins hid many rivets. Any suggestions on replacing that lower panel. Can I get away with a flat replacement, no compound bends. I have a tremendous amount of respect for you airframe experience and guidance. Thanks again
Old 11-01-2015, 02:31 AM   #10
Aerowood's Avatar
Arvada , Colorado
I will be transitioning home from Punta Arenas Chile for the next couple of days, I'll PM you when I'm back home
interior skin scrap for exterior skin patch? badger Ribs, Skins & Rivets 1 06-12-2010 07:56 AM
How to remove silver paint from exterior skin? Zstream Clearcoat, Exterior Paint & Trim 5 05-12-2008 09:21 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Exterior Skin Repair petemoss Ribs, Skins & Rivets 0 10-26-2006 02:49 PM
Type and thickness of exterior skin? reece1107 Ribs, Skins & Rivets 6 02-19-2006 05:23 PM
