Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 02-09-2008, 08:05 PM
Petethefeet
Petethefeet's Avatar
Profile:  1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan, New Zealand
Red face Dope! I think I may have made a big expensive mistake.
Hi, I was just listening to some historical vap podcasts and have become aware that I have used olympics where I should have used buck rivets. I put the shell of my 64 Sovereign back on, using olympics only. I do not mind making a mistake through my own ignorance but luckily the interior skin is still off and I am hoping I can still salvage some sort of integrity by doing the job properly. If it costs me it costs me. If I understand correctly, the perimeter rivet line running around the bottom floor line through to the bottom plate should be held with buck rivets. Does the whole line need to be buck riveted? Is there anywhere else that should be buck riveted?
Regards,
Pete.
Get rid of these ads... register today, it's FREE
Old 02-09-2008, 08:12 PM
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road, Fulltiming
Status: Online
Pete, the entire exterior was buck riveted when new. Many people have used Olympic rivets to reassemble. Buck riveting is a two-person job, and both people need to have experience performing the task, or be ready to spend a lot of time learning.
Aluminitis never sleeps...
AIR#2611
Old 02-09-2008, 08:17 PM
rmpray
rmpray's Avatar
Profile:  1973 31' Sovereign
Bertram, Texas
And have access to both sides of the skin. SOmeone out there must know what the difference in strength is...You can get Olympics in SS can't you, which is probably as strong or stronger than the aluminium buck rivits...but I could be wrong Hey, it might look like one, but it taint an airplane...I've seen some sheered bucks though so it is a very good question.
Catmando
"There’s not much in life we can’t over-analyze”
Old 02-09-2008, 08:25 PM
overlander63
Status: Online
I don't think stainless would be a good option, it would be stronger than the surrounding aluminum, and would contribute to dissimilar corrosion problems. There may be different grades of aluminum Olympics, though.
AIR#2611
Old 02-09-2008, 08:38 PM
wingfoot321
Profile:  1987 29' Sovereign
Sparta, Tennessee
Pete,
I don't know the answer to your question. Let's see what type of replys you receive on this site.
If you don't get good answers to your satisfaction let me know and I will call some of my friends who work in the airstream factory, maintenance area and see exactly what they think of buck vs olympic rivets on a 30 foot trailer.
The guys I know have a lot of experience doing alum repairs and I would have no reservations in following their opinions.
Keep that trailer under a cover or you are going to blind someone with the reflection.
Petethefeet
1957 26' Overlander
Raglan, New Zealand
Okay, so to do the job properly, I am going to have to drill out the olympics and replace them with buck rivets, hopefully I'm a quick learner when it comes to fitting them, any tips? I'll do some trials before starting proper. At least I'm learning and it could always have been worse.
Pete
Old 02-09-2008, 08:42 PM
rmpray
rmpray's Avatar
Bertram, Texas
Good point. From the "No one has tried this before" book, if one packed the rivits with a tiny bit of epoxy, that would reduce the chance of the rivit collapsing thus give it better strength without having to rip them all out...NOt sure if that makes sense or if it would work at all...so you can try it first Just remember the one foru rule...if rob suggest it ... it is probably wise to stay far far away
Catmando
Old 02-09-2008, 09:14 PM
markdoane
Profile:  , Minnesota
I don't think I would rip them all out of they are already in.
Here are the important shear strength numbers:
Pop rivets - about 120 lbs
Olympic rivets - 465 lbs
5/32 2117 Rivets (28 ksi) - 555 lbs
So the buck rivets are about 20% stronger. But I would guess the design is probably a 3X safety factor, so even Olympics are strong enough.
. . . if you keep your running gear balanced.
There's a fine line between a hobby and a mental illness.
Old 02-09-2008, 09:20 PM
Inland RV Center, In
Commercial Vendor
Profile:  Corona, California
Pete
Pete.
The olympic rivets are 5/32 inch in diameter.
The original buck rivets were 1/8 inch in diameter.
If you change the olympics at this point to buck rivets, 5/32 diameter buck rivets will have a larger head on them, than the original 1/8 inch buck rivets.
There is nothing wrong using the olympics for the exterior metal, since they have been used for over 30 years.
What I would suggesy, is that you cover, from the inside, all the olympics, the seams, the horizontal stringers, and the main bows, with a generous coating of Vulkem sealer.
That will add considerable strength to the shell.
Hopefully, you also added vulkem in between the seams of any sheetmetal that you replaced.
If you do the vulkem coating, you will have a shell that is stronger, and certainly will be water tight.
You can also, add regular buck rivets, between the olympics, at the floor line. You can hide that line of rivets by adding some rub rail molding, that's used on current trailers.
Hopefully, this suggestion solves the problem.
Epoxy will not bond to the metal, and stay there very long either.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Petethefeet
1957 26' Overlander
Raglan, New Zealand
I'll sit tight for a couple of days, I was going to have to order buck rivets from stateside anyway, although the quantity sounds like it is about to be amplified somewhat, Wingfoot 321's kind offer is looking pretty good also, it would be interesting to hear that response purely out of curiosity and it is always good to hear options, and yes, I do keep it covered, I'm a bit worried about it becoming a traffic hazard with rubber-neckers driving past my house. Polishing it has been great for my tan, albeit from the neck up!
Pete
Old 02-09-2008, 09:41 PM
Petethefeet
1957 26' Overlander
Raglan, New Zealand
Hi Andy, yes I did seal all the seams where at all possible with Vulkem ( or at least our equivalent here ), also every olympic installed was dipped in sealant before being riveted too.
Can I take it from your reply that if I were to follow all the steps you suggest that it would not be necessary to replace the olympics around the floor line?
When I seal everything up as you say, should the existing bitumen based sealer be stripped back?
Thanks to all for being so forthcoming with the helpful advice.
Pete
Old 02-09-2008, 10:13 PM
Commercial Vendor
Pete
Pete.
Currently, when lower panels are replaced, Olympics are used on the floor line without any problems, provided that the seams and rivets are properly sealed.
If you wish, you can double the number of Olympics at the floor line.
Make sure everything is sealer, properly, from the inside.
I have no information on the sealer you used. Is it equal to or better than Vulkem, for at least 40 years?
Inlandrv.com
Old 02-09-2008, 10:36 PM
Petethefeet
1957 26' Overlander
Raglan, New Zealand
I'll have to do some research on its longevity, it is a Fuller product, called "Metal Grip", classed as a "high performance metal adhesive, interior/exterior, weatherproof, flexible, bonding Aluminium,Zincalume, Galvanised iron, most coated and uncoated metals, steel, concrete, stone, fibre cement sheet, ceramics, wood, glass, fibreglass,plastics,rubber, contains liquid hydocarbons 48%. Properties are Excellent adhesion and flexibility, paintable, uv resistant, surface temp -30 degrees C to 80 degrees C (sorry, cannot find conversion to Fahrenheit)", so I hope that has some comparability to the legendary Vulkem, if not, my decision may have just been made for me.
Pete
Old 02-10-2008, 07:13 AM
overlander63
Status: Online
That is -22 F- +176 F.
If you are operating your Airstream outside those parameters, you have bigger problems than your sealant failing.
AIR#2611
vB code is On
Pingbacks are On
What is the least expensive insurance ctdair Insurance & Claims 13 09-23-2006 12:34 PM
Boy I hope I didn't Make a mistake Jay Wheeler Sprinter and B-van Forum 11 08-29-2006 04:19 PM
Dope slap 101 Janet Off Topic Forum 34 07-18-2006 06:36 PM
The 2500 Mile Mistake. Safari Tim Our Community 15 05-01-2005 04:50 PM
Threaded Gas Line Dope Navigator LP Gas, Piping, Tanks & Regulators 7 03-24-2004 07:16 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
