Old 02-10-2008, 09:17 AM   #15
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
Sounds like I'm in the running at least then.
Petethefeet is offline   Reply With Quote
Old 05-09-2008, 05:22 PM   #16
1964 30' Sovereign
1957 26' Overlander
Images: 14
Knowing just enough to be dangerous.
Hi, thought I would tie up this thread with what I ended up doing. After considering lots of valid reasons from both sides with regards to Olympic vs. Buck, including thru advice from the Airstream factory itself , I decided, for my own reasons to replace the Olympics with the Buck rivet. " Buck it ", I thought " just do a bit each day and you'll be there in no time". The reason I changed them was simply because I could. And sometime soon, that option would have dissappeared behind the interior skin as it went on. I would really like to think that the Sovereign will still be around in another 40 years or so, and that the buck rivets will help that happen.
Old 05-09-2008, 05:48 PM   #17
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Yeeowza, Pete! Mighty fine.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 05-09-2008, 06:34 PM   #18
Baltimore , Maryland
Good for you Pete. You are doing it right in my opinion There are many opinions on the "right way" you chose to do it as it originally was done. I would send you karma if I could...
Old 05-09-2008, 06:55 PM   #19
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Good for you Pete!
You're right.. once you get that interior skin back on, you've lost the chance. Now you can tow knowing that things are correct. As to Vulkem making things stronger... not so sure about that.. just that it makes it sealed. Good on ya for bucking them. We talked about Bucking on last nights show too! One day, we have to bring our Sovereigns together. Very nice trailer.
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-09-2008, 07:05 PM   #20
1964 30' Sovereign
1957 26' Overlander
Images: 14
I decided, for my own reasons to replace the Olympics with the Buck rivet...
Hey, I get to quote myself here, I also meant to say that just because anyone is "pro" something or other, does not mean they are automatically anti anything else.
Pete
Old 05-09-2008, 07:33 PM   #21
robandzoe's Avatar
Plymouth , New York
If you heard
If you heard last night's VAP episode, I stated just that Shari - each situation has to be taken into account. We're Olympic'ing a small panel on the Caravel.. but I'm glad the three panels we did on the SOTR are bucked since we tore her all the way down.
SYDTR!
Rob
Plymouth, NY 13832
Courtesy parking
Old 05-10-2008, 12:54 AM   #22
1964 30' Sovereign
1957 26' Overlander
Images: 14
Thanks Rob, I have admired your own Sovereign for some time myself, they would make quite a picture. As for getting them together, ummm, mate, hows about I meet you half ways, I'm not totally sure but I think that makes it the island of Guam!!
I was wanting to ask another question here, and I realise it is all relative to what you begin with, but broadly speaking, say, for example, one were to rebuild a vintage 30 foot trailer from the ground up, is there more work in the inside of a trailer or the outside of a trailer. I'm just curious to know whether I am nearing half way on this project or not.
Pete.
Old 05-10-2008, 05:27 AM   #23
when you go camping, that is the half way point... all those little details add up to a lot of time.
Old 05-10-2008, 05:33 AM   #24
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I can attest to that. We got 90% done in a few months, we are at 92% now, after nearly a year.
Old 05-10-2008, 05:53 AM   #25
robandzoe's Avatar
Plymouth , New York
More inside
I would state that there is more on the inside of the trailer.. all the things that take time and planning are inside the trailer. Zolatone, flooring, cabinets, electric, plumbing, heating, appliances, interior decorations, seals, locks, faucets, hardware... may I go on and on. I see New Zealand... well, we'll just have to meet in a virtual rally! Check out my latest pictures from this past week.
Plymouth, NY 13832
Courtesy parking
Old 05-10-2008, 11:01 AM   #26
I forgot to mention a shell failure that you should fix.
Hopefully the inside is still gutted.
The shell in your model, above the windows forward of the door, has a great tendency to fatigue crack.
The fix is to double up the main bow section from the inside of the shell.
Adding stiffeners to both the front and rear side of those two windows, adds enough strength to avoid that problem.
The next trick is to have an aluminum material as thick as the main bows, but also contoured to the shape of the shell.
Adding some horizontal stringers above, between and below those two windows will also help. Buck riveting them to the added and present main bows is essential.
The cause of the problem is the weakness of the shell between the entrance door and station "0" which is the first main bow, is the 2 large windows.
Buck riveting those pieces in place is recommended.
Old 05-10-2008, 02:30 PM   #27
1964 30' Sovereign
1957 26' Overlander
Images: 14
Bugger, and here's me thinking I was getting somewhere! Couple more years to go by the sound of things.
Andy, yet again, my thanks to you for your constructive advice, although I am in need of getting up to speed with the terminology.
Firstly, yes (thankfully by the sounds of it), the trailer remains unlined on the interior. Where you refer to the "main bow section", am I correct in taking that term as what I would call the ribs fore and aft of the windows in front of the door?
In the attached pics, the rib running directly between the door and the windows ahead of the door is actually curtailed, then offset to run down between the windows on the opposite side ( factory ). As I see it, the roof panel would be loaded in that offset area.
As for materials, just off the top of my head, I could fabricate and scribe some flat ali' to "flitch " onto the side of the existing ribs, doubling the joins of the flat with another flitch with good laps. I feel like I have an intimate relationship with every square inch of the skin of the trailer after the whole polishing episode, should I be looking anywhere in particular for evidence of this fault?
Should the reinforcement be carried on through to the opposing windows side?
Pete
This feels like such a steep learning curve for me.
ID:	60196   Click image for larger version
ID:	60198   Click image for larger version
Old 05-10-2008, 03:16 PM   #28
Pete
Pete.
Don't give up the ship, er, the Airstream.
So far your doing great.
There is a learning curve to the terminology, but once you learn, it will stick with you better than your name.
The main bows are the ribs, if you wish.
The windows on the door side are the problem, not the road side.
The additions to the main bows forward of the door, only need to go maybe one foot or so, above the top of the wind.
What your trying to do it make a figure 8 from the floor to above the top of the window, forward of the door.
Hope this helps.
Boy I hope I didn't Make a mistake Jay Wheeler Sprinter and B-van Forum 15 03-29-2017 05:32 PM
What is the least expensive insurance ctdair Insurance & Claims 13 09-23-2006 12:34 PM
Dope slap 101 Janet H Off Topic Forum 34 07-18-2006 06:36 PM
The 2500 Mile Mistake. Safari Tim Our Community 15 05-01-2005 04:50 PM
Threaded Gas Line Dope Navigator LP Gas, Piping, Tanks & Regulators 7 03-24-2004 07:16 PM
