Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 02-19-2007, 02:17 PM   #1
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Airstream Registry
Question Does anyone know what this is?
We gave our trailer a good washing and Walbernize’ing this past weekend. We found this on the lower side of two of the rear end cap panels (one on each side, the seam is right at eye level). All the other panels on the trailer, and the other edges of these panels don't have any of this.
What is it? Should I do anything about it? The trailer is still under warranty; is this a warranty item?
Randy
Randy and Pat Godfrey
President, Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 02-19-2007, 02:31 PM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
You have filliform (do a search on that word) corrosion.
Yes, it is a warranty issue, but I don't think it can fixed like it never happened.
Sorry,
Tom
1967 Airstream Overlander International
AL-1
Old 02-19-2007, 02:33 PM   #3
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
Hate to break it to you...but, it appears the clearcoat is compormised in that spot & filiform corrosion/oxidation (which is inevitable) has begun. I don't think much can be done except a panel replacement...the new clearcoat material can't really be patched. Not sure what the warranty covers...
Bummer ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 02-19-2007, 02:38 PM   #4
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I thought that you could re-clear a complete panel at a time?? That of course doesn't address the corrosion...
Warranty!!
Fyrzowt is offline   Reply With Quote
Old 02-19-2007, 02:42 PM   #5
InsideOut's Avatar
1956 22' Safari
Images: 87
Airstream Registry
Warranty!!
Not with the new stuff Airstream is using. It comes from the supplier already coated and can not be touched up with the same stuff...I believe some other clearcoat product can retard the problem, but it is not as durable as the original coating.
Shari
Old 02-19-2007, 02:49 PM   #6
Fyrzowt's Avatar
Images: 8
Bummer.
Warranty!!
Old 02-19-2007, 03:08 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 16
This is one of the more practical posts I've seen on treating this inevitable problem: http://www.airforums.com/forum...tml#post263493
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 02-19-2007, 03:40 PM   #8
Viera , Florida
Airstream Registry
Unhappy Not happy...
Say it isn't so....
The thread that Canoe Stream provided a link to advises to touch it up with some automotive clearcoat touch-up to keep it from spreading then get it to the dealer for a warranty discussion.
I'll do that for now, and probably get it back to the dealer in a month or two. We store it indoors, so hopefully that will keep it from spreading.
Randy
Old 02-19-2007, 03:52 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 87
Airstream Registry
I would be careful about putting anything on it that may void any warranty you may have!
Call the Airstream factory and have them tell you what to do ~
Shari
Old 02-19-2007, 05:27 PM   #10
Profile:  1972 25' Tradewind
Madison , Wisconsin
Deprived of "Newness"?
I am not sure if the same principle applies. a few years ago a friend of mine had a minor body problem with a vehicle that could not be "made new". The defect deprived him of the "newness of the vehicle and after some of the "my lawyer can beat up your lawyer" talk he got a new replacement. It took a bit of agrivation but he did persevere.
Good luck.
Smokin Camel is offline   Reply With Quote
Old 02-19-2007, 06:51 PM   #11
Profile:  , Minnesota
Images: 59
Airstream Registry
I don't like the look of the right hand rivet.
Looks like the bucking bar slipped and the rivet set left a nasty smile in the NE quadrant. That rivet isn't laying flat.
I don't think that led to the corrosion, but it looks bad.
Old 02-19-2007, 06:55 PM   #12
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
The current Airstreams use a coating that is applied at the coil factory. I don't know what the make up is, however if you are getting filiform corrosion at the edges I would suspect that there was some minor "damage" to the panel somewhere along the way either in the factory during manufacture or possibly during the installation. Regardless I would call Airstream and go to your Dealer ASAP and get it resolved. I deal in painted, anodized and coated metals on a daily basis in the Architectural Metals field. We occasionally get a bad piece, nothing to do but swap it out
Aaron
WBCCI #2449 AIR #2495
Old 02-19-2007, 08:21 PM   #13
2airishuman's Avatar
Profile:
hi rodney
where is that? how about a photo with more trailer included?
yes that appears to be a breach in the clear coat and the corrosive result.
IF you expect any warranty support on this DON'T alter it. no touch up paint and NO abrasive anything.
one could put a couple of coat of wax over it, but really u better not fiddle with it.
i agree with mark that rivet isn't perfect and on some panels (depending on the rivetter) there can be many that look this way...up close.
some folks with safaris are having issues exactly like this...
and having the 'classic trim' added to cover it.
trim plus acryl-r to seal the trim and the exposed edge is protected...
just to add to the speculation is that really a BUCK rivet?
i think i see a faint central metal/color change on both rivets, as seen with olympic rivets after shaving....
anyone else see that?
if this were in the middle of a panel the proper resolution IS panel replacement
but i might opt for the classic trim at this site, given a choice.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 02-19-2007, 08:26 PM   #14
Profile:  1960 24' Tradewind
santa barbara , California
Inside Out is correct ,don't try to fix it ,they most likely will not get involved
with it if you have tried a repair .Best to leave it as is so they can clearly see the trouble.fixing it up may lessen it to the point airstream doesn't feel it needs adressing .they them selves could use some kind of clear coating to
fix it ,all in all Id suggest to not touch it ,by all means get it repaired when you can .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Mustang Forums - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - RV Forum - Truck Conversion - U2 Music Forum - Campground Reviews - Forest River - Sunline Trailers - Fiat Forum - Retirement Calculator
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© copyright 2002-2010 Social Knowledge, LLC All Rights Reserved.
