Old 01-14-2009, 11:27 PM   #1
Augie R.
1960 22' Safari
carlsbad , California
Diferent types of Aluiminum
Hi there folks,
So i tried what I could find at my local Home Depot for stripper before I buff away....I noticed something wierd when I tried a section. I have attached photos for you to see. One patch of the exterior looks diffrent for the rest. Is there diffrent types of aluiminum ? And when I tore out my inside panels today to replace my floor I noticed I have to replace some sections becuase the bottom of them ar eaten up by corrosion....Now here's the part I'm really confused about what thickness and type do I ask for when I call whoever it is I'm going to have to call once I find out who that place or store is......(very confused) Anyway Thanks for taking the time..........
Name:	gel Stripper.jpg
ID:	73994   Click image for larger version
Name:	diffrence in  aluiminum.jpg
Name:	Lower half tested.jpg
ID:	73996   Click image for larger version
Name:	Stripper applied.jpg
augier is offline   Reply With Quote
Old 01-15-2009, 04:07 AM   #2
Baltimore , Maryland
AirParts Inc. has all the aluminum you might need. The skin is 2024 T3 .032. That patch is probably 5053. It will polish, just not like the rest of the skin. Those pop rivets are probably letting water in too. At the minimum replace them with olympics. That patch is probably where an awning was at one time.
Old 01-15-2009, 05:54 AM   #3
Kevin245's Avatar
I would definately replace the rivets. As for replacing the patch...Personal Preference prevails. If it were me, would replace the rivets and while the patch was off I'd radius the corners and re-install. The radiused corners make the patch look professional (My Opinion) and they reduce the likelyhood of the sharp corner catching your clothing, or worse flesh.
Keep us posted.
Kevin
Eleanor Roosevelt
Kevin245 is online now   Reply With Quote
Old 01-15-2009, 10:15 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Here is a good source for sheet Aluminum
Airparts, Inc.
.032 thick 2024-T3 ALCLAD ALUMINUM
You can get rivets@ Vintage Trailer Supply - Vintage travel trailer parts and supplies!
10% discount till the end of the month!
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Types of brakes that comes on AS davidachoi Hitches, Couplers & Balls 9 02-25-2008 08:04 PM
Rivet Types lee Ribs, Skins & Rivets 2 08-02-2003 07:59 AM
