View Poll Results: What color would you cover you interior in
Cognac 2 66.67%
Black 0 0%
Shade of Blue 1 33.33%
All White 0 0%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Old 08-30-2014, 10:13 AM   #1
Lake Forest , Illinois
Question Did I Goof?
Complete Newbie here -
Restore cars - never an Airstream, but am completely enjoying the experience.
I have one or two fairly significant scratches in my 1972 Overlander Land Yacht. I used 600 grit sandpaper (for 5 minutes at most) on the scratch - thinking that I could move up on the grit level to blend the scratch.
Then I realized that I could/might have removed some of the coating - as the area I sanded became lighter than the area I was already buffing.
Can I repair this - or do I need a new panel? I am going to try to buff it out with Nuvite today - and see what it looks like.
If a new panel is needed, I'll do that as well.
Can post a picture after I work on it again today.
Also, does anyone sell kits - or parts of kits, that fit into Airstreams - you know - couches, bunks, sinks, bathrooms. Haven't found a one on line - might be a business I'd consider starting (serial entrepreneur).
Thanks so much for helping me through this exciting restoration.
Also, - I want to add solar to my unit and A/C, in fact, will be replacing all of the major mechanicals - so if anyone could recommend the preferred vendors, I'd be thankful.
Ok, back to polishing.
Paul
PJBWFG is offline   Reply With Quote
Old 08-30-2014, 10:41 AM   #2
Paul
Polishing that scratch will onlky make it worse.
The polished part will look bright and shinney as a mirror, when the rest of it will look somwhat dull.
Also, the clearcoat only lasts 5 to 6 years, and then must be redone, or leave it alone. The clearcoat will peel in sections all by itself, and then the oxidation process will set in.
There is only a couple of Airstream dealers that deal with many parts.
However, there is one non-dealer who sells many Airstream parts, but the factory will not honor any warranty if you buy it from them. Airstream has stated that in writing.
Since your new to Airstreaming, the first large step is making the trailer water-proof. All the exterior gaskets will need replacing, if not already done so, especially the sewer vent pipe cover gaskets which only last 2 to 3 years.
Checking the axles out should be done when the trailer is more than 25 years old, and/or especially if the coach was parked for an extended period of time.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-30-2014, 10:56 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Sorry, can't help you with the scratch. We are just entering that phase!
We bought our replacement appliances from a variety of places when on sale: Camping World, Vintage Trailer Supply, Out of Doors Mart, Inland RV. There are others on the internet and sales are the time to buy. We tended to spend winters shopping and summers installing....
I have not heard of kits for interiors, but many people sell their interiors when they are gutting, parting out, or upgrading. You could check the classifieds for these. Cabinets are usually stick built, upgraded from what's there, or sometimes prebuilt cabinets that are modified to reduce weight and fit the trailer curves.
Good luck, and welcome to the Forums!
Kay
Old 08-30-2014, 11:07 AM   #4
Kay,
Thank you for the reply. I was thinking of building repeatable kits - as I am going to gut (and sell) the complete interior of our 1972 Land Yacht. It's all in excellent condition but I am looking for a "hotel" look.
Many thanks for the reply.
Paul
Old 08-30-2014, 12:35 PM   #5
Andy,
Thanks so much.
I did, however, remove the clear coat. This was a scratch I was attempting to blend after the clear coat was removed. Hence the question of buffing. I've since started to compound it again and it's getting better, leading me to believe that I may not have affected the "alumicote" or whatever they call it that is put on aluminum used by Airstream.
I will check the axles also.
My thanks
Paul
I did look I really did bennu36 Sprinter and B-van Forum 11 08-12-2013 01:01 PM
Goof or good? Skamper1 Cleaning, Stripping & Polishing 3 03-29-2010 04:54 AM
How did you get into Airstreams & Airstreaming? 83Excella Our Community 102 03-15-2009 09:48 AM
its thursday and to 2airishuman is my favorite goof except the others... Boondocker Off Topic Forum 9 02-17-2006 12:22 PM
