Old 06-26-2004, 06:15 AM   #1
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Dent work -- before and after
We purchased a Bondo suction cup dent puller from Wal-Mart and easily "popped" this dent from the outside.
ID:	7322   Click image for larger version
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 06-26-2004, 06:38 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Kewl~
Be sure you bring it with you to a Rally..
Fantastic results~
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-26-2004, 07:10 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
good timing! I just dented the rear panel on mine. Not too badly but it bugs the heck out of me! On the way to Wal Mart now....gove it a try if it doesn't work I can always take it back...Sam doesn't mind.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-26-2004, 07:14 AM   #4
yukionna's Avatar
Massachusetts
Images: 18
If you don't find it at Wal-Mart, we have also seen them at auto part stores. BTW, the dent puller cost us a whopping $2.99!
WBCCI Region One
Old 06-26-2004, 01:29 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
found it at Pep boys. Never noticed them before... only saw the glue on dent puller ... anyway 3.49 and the dent is about 85% gone.
The only catch with this suction cup is that it needs a mostly flat area to work on..(duh) the smallest part of the dent was on a spot it could not pull up. Most of it is gone though and looks way better. It also partially pulled out a small ding that was on a seamed section of the hood...not all the way but it also is better. I heated that one with a hair dryer, and then pulled it. I also got behind it with a rubber handled large socket wrench breaker bar, used the rubber area with some leverage to push this hood dent out. Not 100% but closer.
The photo is the before. I will try to post the after , later on.
AIR #005
retired!
Old 06-26-2004, 03:57 PM   #6
Obsessed with Moonunit
COArgosy78's Avatar
1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 55
Hey, we're going to pick one up for those long camping trips when there is nothing else to do, but build up a nice warm fire and pull dents . Seriously, it looks to do a pretty darn good job and worth the $2-3 to smooth out the dips!! Thanks for the info.
Leigh (IB Aluminated)
"When a great ship is in harbour and moored, it is safe, there can be no doubt. But that is not what great ships are built for." by Clarissa Pinkola-Estes, author of ‘Women Who Run With the Wolves’
COArgosy78 is offline   Reply With Quote
Old 06-26-2004, 06:57 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I wish someone made a smaller version of the thing for smaller hard to attach to dents. It just might do the trick. considered the glue on model , but not sure about what it would do to the clear coat, although its supposed to be harmless.
AIR #005
retired!
Old 06-26-2004, 09:22 PM   #8
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Where did you find the '64 Nancy?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 06-26-2004, 09:40 PM   #9
yukionna's Avatar
Massachusetts
Images: 18
It was in a field behind someone's house in Franklin, New Hampshire. We were staying at a campground just a few miles south and spotted it on our way back to the campsite one afternoon.
I posted a separate thread with links to pictures:
http://www.airforums.com/forum...ad.php?t=12104
WBCCI Region One
Old 06-27-2004, 05:08 AM   #10
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Thumbs up
I went to see Nancy's trailer yesterday, and it is extremely cool. even more than the pics indicate. great find!!
we had to duck inside it when the heavens opened up, and after a few minutes, some leaks revealed themselves... but they should be pretty easy to fix.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-11-2004, 09:46 PM   #11
Smile
Thanks for the tip. Our Excella just sustained a dent about the size of a dinner plate from a falling tree limb. I'll give it a try.
afay is offline   Reply With Quote
Old 07-11-2004, 09:54 PM   #12
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
They work. I didn't experience any problems using the glue-on kind with the clear coat. Removed a shallow dent about the size of a man's head in one of the upper curved panels. Those are supposed to be the bad boys for dent removal. To replace the panel was estimated to cost $1,586. That is a pretty impressive savings.
GStephens
GStephens is offline   Reply With Quote
