Old 08-03-2014, 06:37 PM   #1
providence , Rhode Island
dent repair estimates
Hello Everyone,
I'm new here and wanted to thank everyone in advance for a really well run forum, I've been looking around here for about a year now and have learned a great deal about great trailers. I've been given the trailer in the pics attached and was wondering what folks think it might cost to fix the dents in the exterior. Thanks again for any replies.
-James
ID:	218186   Click image for larger version
ID:	218188   Click image for larger version
jdean13 is offline   Reply With Quote
Old 08-03-2014, 07:23 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello Jdean. You are now the proud owner of an old Trade Wind and also own all of its needs. Body work on aluminum Airstreams is expensive. The crease on the curb side behind the door might need a big new Alcad sheet to make it like new. The dent in the front segment would also likely need a new panel. However, this dent looks like it could be pulled or rolled out and made to look much better, but not like new. This would be less expensive repair. Most old Airstreams, except for the show girls, have cosmetic issues. I have come to live with my hail dents. I had a crazy dealer quote $50,000 to replace the hail damaged roof and end caps on my 86! I decided to pass.
Both repairs would need access to the back side of the panel from the interior. Thus the interior cabinets and inner skins and front cap would need removed along with the old fiberglass insulation. Wow, now you can see the floor rot, the leaks, the corrosion, the bad wiring, the rusty furnace, the split copper pipes, etc. There's LOTS of labor involved.
Chances are this old Trade Wind has many needs more urgent than cosmetics. If you plan to renovate, you can address the body damage "while your at it" with all the other projects. Some folks actually separate the body from the frame and then begin to rebuild the trailer from the ground up. Your trailer has value as it sits to crazy people like me who enjoy renovating them, especially 1960s trailers.
There are very good Airstream shops in the northeast that can repair the bodies (shell) with no problem. Maybe one of these experts can chime in and get you an estimate. My guess it would be over $4000.
David
Old 08-03-2014, 08:45 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
end cap will pop out as for the beauty mark on the side as long as it does not penitrate the skin i would leave it for now!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 08-03-2014, 09:07 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Yeah... Attend to the important structure of floor, running gear, devices then decide if you want to or need to do a frame off resto.
Peace and Blessings..
Channing
WBCCI# 30676
Sneaky. Now what? Subfloor estimates... simple sanctuary Repairing/Replacing Floor &/or Frame 15 04-01-2014 07:44 PM
Gaucho upholstery yardage estimates trearick Upholstery, Blinds, Walls & Interior Finishes 12 09-24-2012 11:18 AM
Labor to replace flooring ||| Wide range of estimates JakeSpoon Floor Finishes 1 07-06-2010 10:11 PM
Consumption Estimates campadk Electrical - Systems, Generators, Batteries & Solar 8 02-03-2007 09:54 AM
Estimates from Jackson Center? Kistler Commercial Listings 18 12-15-2003 01:14 PM
