Old 12-25-2014, 11:53 AM   #1
2001 23' Safari
Ironwood , Michigan
Dent Repair
My 2001 Safari has a few dents that I would like to have repaired. I read in posting a while back that there was a guy who used to work for Airstream and now has his own shop near the factory. Does anyone know who that may be?
Any recommendations would be appreciated. We'll be going thru central Ohio in a few days.
jodygordon is offline   Reply With Quote
Old 12-25-2014, 12:42 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Can't help you with the ex-Airstrteam guy, but you might want to explore the dentless paint repair shops. They can do magic with cars, probably the same with aluminum.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 12-25-2014, 12:55 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Paintless dent repairs count on access to the rear in most all cases. Also, aluminum does not respond to their techniques as well as steel. May work to some extent if they can get behind but...... Now if it can be pulled from the outside there might be better success.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-25-2014, 01:04 PM   #4
TinTin's Avatar
Canmore , Alberta
The rear of the outside sheets can be accessed in many locations by removing a few interior pops ... I had PDR done on an aluminum car hood, flawless job.
Bob and Nancy
Old 12-25-2014, 01:46 PM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Dent King repair
Depending on low perfect you want it, Dent King will pull out minor dents without damaging the clearcoat on your unit. I have used it on a 1977 model and a 1963 Overlander.
Old 12-26-2014, 01:07 AM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Look at smaller regional airports - for someone who maintains aircraft. Airplane bodies are aluminum. The techniques are the same.
Paula
Old 12-26-2014, 12:43 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Working with aluminum is much different than steel. Aluminum tends to stretch and thus never recover to it's original shape. Access behind the dented panel is likely necessary.
I tried paintless dent repair on some 1" diameter hail dents with very limited success. I also tried heating and freezing with no success. I did use a suction cup on my son's Airstream with some success. A orange construction barrel jumped out in front of his curb side front curved panel. I was able to "oil can" it back to shape except for the crease. Better than it was.
Jackson Center can make any dent go away. For a price.
David
dbj216 is online now   Reply With Quote
Old 12-29-2014, 04:27 AM   #8
1977 31' Sovereign
1989 34' Excella
The aluminum "temper" is not the same for all panels. The compound stretched panels, in the hemispheres, are softer, so they can be stretched to shape in the factory. Dents in them stretch the aluminum and cannot be pulled out. Simple curved panels and flat panels are harder. Bumps in them, that do not result in stretching, can many times be pulled or pushed out with "acceptable" results. Sometimes a dent roller can be used, if the inner skin is removed. Use of a "Dent King" puller is a cheap $29 fix.
Old 01-06-2015, 06:18 PM   #9
1968 24' Tradewind
Carlsbad , California
Any idea on how to get a hold of a good dent roller? I saw one that someone was using from Aerowood. Not sure if he is selling those or if they can be fabricated/purchased locally?
shilgemann is offline   Reply With Quote
Old 01-06-2015, 07:41 PM   #10
1987 25' Sovereign
Oregon , Ohio
You might give P&S trailer service a call @ 419-638-6261. They are located in Helena Ohio on SR 6 about half way between Bowling Green and Fremont.
msmcv51 is offline   Reply With Quote
Old 01-06-2015, 07:44 PM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
"Dent King" is a professional removal service. Were you referring to the "Ding King" dent puller that uses a glued on suction cup with a bridge to pull out dents? Do you have any experience using one on an Airstream? I have a couple of dents from a hose roller on my garage wall.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 01-12-2015, 03:19 AM   #12
1977 31' Sovereign
1989 34' Excella
I bought a Dent King from a local auto store. It worked for simple smaller dents. It did not work well for hemispheres. $15 and a little time is worth the experiment.
Old 02-23-2015, 02:24 PM   #13
2012 25' FB Flying Cloud
albany , Georgia
It works.
$139 and it works.
RED Hand Lifter Kit | Dent Tools Direct USA
jmpgino is offline   Reply With Quote
Old 04-30-2015, 06:16 PM   #14
MtnCamper07's Avatar
1993 30' Excella
Salida , Colorado
I have a couple of dents on the upper rear of my TT left as a gift by the PO. I thought I would include some pics to see if you might look at them and give an opinion as to the ease/complexity of repairing the dents. Can I fix this from the outside or will I need to have access to the interior (behind the dent). Can I do this myself? Please feel free to include your suggestions for the recommended repair method. Thanks
NB
MtnCamper07 is offline   Reply With Quote
Dent repair options automatik Ribs, Skins & Rivets 11 11-03-2006 03:23 PM
Dent repair? gflatt Exterior Restoration Forum 2 07-06-2006 09:53 PM
dent repair in oregon nevisstudio Ribs, Skins & Rivets 6 08-25-2005 11:40 AM
Dent Repair AccessMaster Ribs, Skins & Rivets 4 08-26-2003 05:35 PM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
