Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 11-13-2004, 08:24 AM   #1
ASFlorida25
Profile:
Unhappy Dent Removal/Hurricane damage
Still searching for the obvious......need insights on repair of large dent in front top corner of 25 CCD caused by large limb falling. 15 inch diameter....how best to remove. No rivet damage evident, and no leaks so far. Deepest indent is about 3 inches.....looks bad, but no evident damage inside.
How to remove
ASFlorida25 is offline   Reply With Quote
Old 11-13-2004, 09:01 AM   #2
joecj76
Profile:
I used a plumbers helper and a little vegetible oil. Start at the very edges and work your way around the dent untill it is gone. Very low tech...but works well.
any help would be....ah.....most helpful!
joecj76 is offline   Reply With Quote
Old 11-13-2004, 09:31 PM   #3
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Try a hair dryer and ice. Heat the area then apply the ice to shrink the aluminum. I took several nice size dents out using this method.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 11-13-2004, 09:36 PM   #4
robandzoe
robandzoe's Avatar
Profile:  1958 30' Sovereign of the Road
1965 17' Caravel
Plymouth , New York
Images: 26
Ding King
I've used a Ding King Dent puller, and it works quite well. just use it on the center and pull straight up and out.
Rob
Rob, Zoe', Stanton, Bryce and Braedon Baker
WDCU President
Do you Listen to the www.theVAP.com
Plymouth, NY 13832 WBCCI #2820
Courtesy parking (607) 334 4960
58 30' Sovereign of the Road:
http://sweetsovereign.blogspot.com
65 17' Caravel, 54 22' Safari, 1959 Buick Electra
robandzoe is offline   Reply With Quote
Old 11-13-2004, 09:52 PM   #5
Tarheel
Tarheel's Avatar
Images: 21
I have one and it works good if the dent isn't too deep. Mine were more than the dent puller could handle that's why I went for the shrinkage method.
WBCCI # 3485
Region 3 1stVP
Old 11-14-2004, 10:25 AM   #6
GStephens
GStephens
GStephens's Avatar
Profile:  1982 31' Limited
Hamilton , Texas
No more than the professional dent pullers charge, I'd have it professionally removed. A paintless dent puller removed a large shallow dent from one of my curved panels last year after a technician at a "camper repair" place crawled up on the roof and put his weight on the curved section where there is no support. The charge was only $150 verses over $1500 to have the panel replaced. I can't tell a dent was ever there and the panels still match whereas replacements would not have matched.
If the dent is deep or creased then dentless repair might not be the way to go, but it sure worked in my case. Most any automobile dealership can put you in touch with a professional paintless dent repairman.
GStephens
GStephens is offline   Reply With Quote
Old 11-15-2004, 08:35 PM   #7
ASFlorida25
Profile:
thanks......is it safe to assume a panel replacement is about $1500 on a top corner? We might be able to claim insurance.....and thus if it can be done it might be better than a $200 dent man with our 250 deductable.
Old 11-17-2004, 09:35 AM   #8
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Segment and quarter panel replacements, cost an average of about $1000.00 to replace, not $1500.00.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-17-2004, 01:38 PM   #9
GStephens
GStephens
GStephens's Avatar
Hamilton , Texas
Guess everyone doesn't tow the line and give customers as good a value as you do Andy. Though I don't think youintended it that way, your response could be interpreted as insinuating that I made up the damage estimate of $1500.
The truth is that I received the estimate of $1,583.10 from Mack's Camper Sales of Waco, Texas. Mack's is the facility who put the dent in my trailer in the first place. One of their workers got up on my trailer (in my presence). He accessed the roof from a ladder placed at the corner of the trailer. Oops! and the trailer was dented. Mack's admitted their error and made the estimate for the own insurance company to cover their mistake. Perhaps they might have been trying to take advantage of their own insurance carrier. I don't know. Given the fact that they were the ones who put the dent in the trailer in the first place, I wasn't going to let them do the work, but I did accept a check from their insurance company for $1,583.10
I fully intended to have the panel replaced, but as I began researching panel replacement and talking with Airstream dealers, I became concerned that a replacement panel would not match up. I was told that replacement panels produced today have a different finish to what was used on my 1982 Limited. Further, the plasticoat formulations used now are considerably different formulations than what was used in the past. I'd already accepted a settlement without provision for having the trailer replasticoated all over. I therefore elected to try pulling the dent. Fortunately, it worked extremely well for me. It has now been almost a year and the dent has not returned. I cannot tell it was ever there. If someday it does pop back in, then I'll replace the panel.
GStephens
Old 11-17-2004, 06:16 PM   #10
Commercial Vendor
GStevens.
A non Airstream dealer will almost always have a higher estimate, for a couple of reasons.
Since they must buy the parts from an Airstream dealer, not the Airstream factory, they must accordingly charge more for the parts.
Secondly, usually a non Airstream dealer has never replaced segment, therefore inflates the time factor to cover themselves.
Generally speaking, it is not wise to have any dealer replace sheet metal on an Airstream, unless they have at least been to the factory and learned how to do it, correctly, with the right rivets, sealers and procedure.
Correctly, and with quality, is the key.
It is very difficult to see "any" difference between the appearance of the new metal and yours.
You will see a difference because your trailer is clearcoated with plasticoat and the new material has a very different type of coating, that cannot be done in the field, or even at Airstream. However in time, it will blend in very well.
Inlandrv.com
800-8777311
Old 11-17-2004, 07:58 PM   #11
GStephens
GStephens
GStephens's Avatar
Hamilton , Texas
As always Andy, you're the best. I really mean that. Thanks for the explanation.
GStephens
Old 11-18-2004, 07:19 AM   #12
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
as for the paintless dent repair guys- I thought they were reluctant to work on Aluminum?
I have not yet tried them but have a golf ball like dent in the front of my motorhome which is on the crease of the hood area. It has come out some with me working it from behind with my limited tools, heat, and pressure, but a dent wizard type repair might be just the thing to get it out the rest of the way.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 10:15 AM
Urgent: frame damage caused by improper jacking? Rog0525 1969-1971 Caravel 39 03-31-2004 06:35 PM
thanks for the advice on the dent wayne.yl Ribs, Skins & Rivets 8 11-07-2003 06:23 AM
The dent, another question... Kistler Our Community 1 08-24-2003 01:40 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 8 10-18-2002 11:37 PM
test
