Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-28-2002, 03:46 PM   #1
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Dent Removal
My trailer had a basketbal sized dent in one of the curved panels in the rear above the rear facing window. It seems somewhat soft, so when touched the aluminum still has some give to it. i would liek to pull it out, or have it pulled out professionally.
Question:
Anyone had any luck with paintless dent removal companies working on an airstream?
Anu suggestions on removing this dent? It is not accessible from the inside very easily. It is behind some cabinetry on the streetside of my 71 tradewind.
So many projects, so little wine......
Uwe
Old 06-28-2002, 10:06 PM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
Is it in the middle of the panel or along a seam? If its in the middle, try a plunger or smaller suction cup to see if you can "pop" it out.
The "dry ice" method will not work on aluminum. (I just know someone will recommend it)
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-29-2002, 09:57 AM   #3
uwe
418
uwe's Avatar
Images: 40
Dent Removal
I went and borrowed some professional dent suction cups last night, and I will try them out today.
One of them is air powered.......scary.
The dent is fortunately in the middle of a panel, not along the riveted edge.
I will let you all know how it went. maybe I try some " before and after" pics.
Uwe
Old 06-30-2002, 07:56 PM   #4
uwe
418
uwe's Avatar
Images: 40
Dent no more
Update:
I used the suction cups today, and was able to pull out the dents with relative ease. The biggest one of them ended up with a very slight circumference crease, but diligent and very light hammering of the crease with a plastic hammer took care of this as well.
Sorry, forgot to take pictures.
Uwe
Old 06-30-2002, 08:08 PM   #5
BobbyW
BobbyW's Avatar
Houston , Texas
Just like "New"
Great news. Glad things worked out right.
I really wanted to hear about the "Scary" air powered one. Sounds like a tool for frightening small children and pets.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Old 07-01-2002, 08:00 AM   #6
uwe
418
uwe's Avatar
Images: 40
Suction
Hi Bobby,
I did not have to use the air powered one. That one uses compressed air to evacuate the area behind the suction cup, so that you get a stronger seal, and can use a slide hammer type apparatus. I used a wet towel to clean the area, and then a 4" suctioncup with handle to gently pull things into perspective......
The air powered one is also good for areas where the additional pressure needed to install the suction cup is not beneficial.
Thanks for everyone's tips and concerns.
Uwe
Old 11-13-2004, 08:56 PM   #7
Tarheel
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Were your able to get to the backside? The paintless dent people that I talked to wouldn't try to work on mine because of the difficulity of getting to the backside.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is online now   Reply With Quote
Old 11-14-2004, 09:15 AM   #8
GStephens
GStephens
GStephens's Avatar
Profile:  1982 31' Limited
Hamilton , Texas
A dentless repairman successfully removed a dent in a rear curved top panel from my unit last year. You litteraly cannot tell it was ever there. He charged me a $150. Replacement of the panel would have cost over $1500.
GStephens
GStephens is offline   Reply With Quote
Dent and replacing light fixtures imeynstein Lights - Interior & Exterior 5 03-30-2004 01:56 PM
dent removal nevisstudio Ribs, Skins & Rivets 8 01-14-2004 12:45 PM
thanks for the advice on the dent wayne.yl Ribs, Skins & Rivets 8 11-07-2003 05:23 AM
The dent, another question... Kistler Our Community 1 08-24-2003 12:40 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 8 10-18-2002 10:37 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
