Old 07-03-2010, 05:58 AM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Dent Puller
This dent has been bugging me for about 10 years. I got fired up at the Restoration Rally by UWE for using suction cups to pull out dents. I happended to see some 4-1/2" suction cups ($5) at Harbor Freight a couple days ago, so I thought I'd give it a try. It was a bit of a challenge to get the cup to adhere--I think a smaller diameter might adhere better but it might not have the "pull" to pop a dent out.
Name:	P1000163 dent-s.jpg
ID:	106174 Click image for larger version
Name:	P1000166 dent fixed-s.jpg
Not perfect, but much improved. Now, if only I had access to the inside of the dome skin, I know I could roll the skin to an almost perfectly smooth finish.
I tried the suction cup on a dent in the dome of the Overlander, but the shape of the dent prevented the suction cup from getting a purchase. I think I'm going to build a vacuum box to fit the section of the dome and see if that will pull out the dent. I really don't want to have to go at it from the inside--that would require cutting the interior plastic dome.
I used wooden blocks to fix dents in the Caravel banana skin, but even though the skin was much improved, the blocks left a number of small welts. (There is a longer thread about this posted in 2006.)
Name:	IMG_5794 front banana-s.jpg
ID:	106176 Click image for larger version
Name:	IMG_5865 shaping block-s.jpg
Name:	IMG_5867 finished banana-s.jpg
I did the same technique on a banana skin dent in the Overlander down at the Restoration rally, but I finished the job with Kip's roller. The skin turned out to be almost perfectly smooth. We gotta get Kip to make us a bunch of those rollers!
Name:	IMG_0331 banana dent-s.jpg
ID:	106179 Click image for larger version
Name:	P1000182 banana fix-s.jpg
Zep
Old 07-03-2010, 06:09 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Looks great! I've seen a lot of dented banana skin--the roller really did a great job of smoothing it out--can't even tell it was ever dented. Nice!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-03-2010, 06:48 AM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Not having Kip's metal work expertise I found a 2 in bed frame roller at HD and put a 3/4 in. pipe on the end and rolled out the dent.Luckily I have the skins off.Not perfect but looks 80% better considering there was a gash in the dent that was not removable.Kip still needs to produce these rollers.
bwaysteve is offline   Reply With Quote
Old 07-03-2010, 07:00 AM   #4
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Do you have a picture of the roller? I'm in the process of fixing some dents on my GT. This was done from inside.
ID:	106181   Click image for larger version
JLGT5107 is offline   Reply With Quote
Old 07-03-2010, 07:11 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have one of those pullers for my rear dent, I'm having the same problem with getting it to stick. did you use water? or something. When I did get it to stick it just popped back. Is it better to try when it is warm?
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-03-2010, 08:49 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You guys are going to force me to make more aren't you
Kip
ID:	106184   Click image for larger version
Old 07-03-2010, 09:17 AM   #7
JSTOTT's Avatar
1965 26' Overlander
Chapin , South Carolina
Nice roller idea. I wish I had one of those about 3 months ago when everything was apart. Those banana skins turned out nice.
Russ
JSTOTT is offline   Reply With Quote
Old 07-03-2010, 09:31 AM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Try pushing it on and then duct tape it down.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 07-03-2010, 09:35 AM   #9
1975 31' Sovereign
1977 23' Safari
Yes, I used water. The skin was HOT from the afternoon sun, but that was random luck, if, indeed, it had anything to do with getting the dent out.
I have actually heard it is better to do when it's cold. Some say that dry ice will shrink the skin and force the dent to pop out. The theory is that the skin is stretched a little when it deforms into a dent and the cold shrinks it back for long enough to pop the dent out--once it's out it's now overcented in the "out" rather than the "in" position. I'd sure like some feedback on this. I'm thinking it has to work only for small dents.
UWE recommended to put the suction cup on and while pulling, lightly tap the edge of the dent with a dead blow hammer, like copper or a bead-filled hammer. I used a 2-lb rubber mallet. I'm not sure it did anything, because the dent came out almost immediately. Maybe it helped do something with the curl at the edge of the dent to ensure it wouldn't fold back in. Don't know.
Zep
Old 07-03-2010, 09:46 AM   #10
purman's Avatar
1968 28' Ambassador
thanks I will have to give it a try, I might try the dry ice idea. I will let you know how it works out..
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-03-2010, 10:38 AM   #11
JLGT5107's Avatar
I have one of these type rollerers used for flastic laminate. I think I try sanding a curve into it. Its a hard rubber roller
Old 07-03-2010, 02:38 PM   #12
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Arrow
Here is a link to Zep's former thread that he mentioned in the 1st post up above.
[http://www.airforums.com/forums/f476/banana-skin-dents-repair-24690.html]
Dent Puller 2006 http://www.airforums.com/forums/f476...air-24690.html
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 07-03-2010, 06:24 PM   #13
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
a little body work lingo
when a smooth rounded panel is fab'd by the factory, it is a "low crown" panel. When a panel has a highly defined lip, edge, or detail, it has a "high crown" component. So, when a smooth rounded panel is dented, it now has high crown components at the edges of the dent. The actual center of the dent is not deformed, just the edges. so, if/when pulling a dent, you wish to have enough pull to overcome whatever force caused the dent in the first place-pull in the opposite direction, and do not attempt to cause deformation at/over the edges of the dent. Now, the "over deformation" is actually at the edges of the original dent. Very light application of force in the opposite direction of the dent removal force can/will "shrink" the pronounced high crown of the dent edges, smoothing out the entire blemish such that only a highly trained eye will even notice.
Okay that is the theory, practice on scrap, zepp until you can wield a mallet of choice with aplomb. easy goes it, you are on aluminum, not steel. small amounts of heat may also help the metal to remember its orig shape. too much and you will expand the metal requiring more heat with even more cold damp rag application which will shrink the metal even more. The british used to hand form aluminum auto bodies-it wasn't done much in the USA, but Healys and perhaps some MG's as well as Jaguar's had aluminum in their skins. Aluminum can be worked, it is just painstaking time consuming labor-which of course, all A/S owners have, especially those whose name begins with Z. Ya know, I'll bet if a guy did a search on the internet on aluminum metal working there'd be something out there.
wmarsha is offline   Reply With Quote
Pro Quality Dent Puller? fotochop Ribs, Skins & Rivets 23 12-24-2010 06:50 PM
DIY dent puller kit flmgrip Ribs, Skins & Rivets 9 06-07-2010 08:41 AM
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
Airstream Puller - with Ford TD FrankR Tow Vehicles 0 05-16-2002 10:45 PM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
