Old 03-17-2007, 09:12 PM   #1
2006 19' Safari
Flagstaff , Arizona
Dent
Hi everybody,
I'm in the process of getting our 2006 Bambie 19 ft. Safari in shape for the summer. There is a large dent on the street side of the trailer in the rear to the left and above the rear window . The aluminum has not been punctured and I would like to know what is the best way to repair it. We feel that some dings are a sign of characture but this one way past characture. Please let me know what you think.
Thanks, Flyguy
flyguy is offline   Reply With Quote
Old 03-17-2007, 09:15 PM   #2
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Best thing to do would be to post a couple pics showing the dent. As I understand it dents are impossible to make perfect because the metal stretches and creases are forever as well. But I wouldnt want to be quoted on that. In any case, pics will make it easier for the ones in the know to help. Good luck.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-17-2007, 10:20 PM   #3
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
I have a few on my moho and I was going to leave them be, but my brother told me to try the suction repair that alot of shops are doing these days. I haven't yet, but I'm willing to go for an evaluation. They may not be able to if the aluminum stretches as has been said here.
1992 Airstream 300LE, rear queen, Banks Power!
Astrodokk is offline   Reply With Quote
Old 03-19-2007, 10:30 PM   #4
2006 19' Safari
Flagstaff , Arizona
Thanks for your input. The dealer is going to see if it can be suctioned out. I hope that this works. If not they said to really repair it would cost $2200.00. Ouch!! I'll see what comes of the suction job and thenmaybe just chalk it up to character.
Thanks again
Flyguy
Old 03-19-2007, 11:27 PM   #5
AZstreamin's Avatar
2005 30' Safari
Chandler , Arizona
good god are you kidding me... $2200 of dent is not character it's an insurance claim. Its brand new why wouldn't you fix it?
AZstreamin
"Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bowlines, sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."- Mark Twain
AZstreamin is offline   Reply With Quote
Old 03-20-2007, 07:21 AM   #6
Royce's Avatar
1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I agree with Azstreaming. Insurance claim.
If you decide to pull, suction may not be the best way. The key to dent removal is to reverse the process in slow motion. You may not get the dent anyway but at least you have a better chance. Suction doesn't have enough finesse to do that unless the dent is just the right size. I always pull from the outside edge and then work my way to the middle. First in last out. Hot melt glue and many contact points. Pull a little at a time from each point. Gentle and go slow. Zen sorta of thing.
Royce (K0RKK) 146.460 simplex
Web page http://spearfishcreek.net/
AIR# 3913
'77' Minuet 6 Metre, behind a 2005 stock Jeep Rubicon with Equa-L-Zer hitch.
Royce is offline   Reply With Quote
Old 03-20-2007, 10:37 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I bought my dent "used". I decided to leave it as a beauty mark.
Pat
pmclemore is offline   Reply With Quote
Old 03-20-2007, 11:37 AM   #8
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
There have been some related threads on this issue that you may find if you search.
Some methods that reportedly work are toilet plungers or other suction type devices. I think if you try to do it yourself, I would do it on a warm/hot day or use a heat lamp to warm the skin. Then try to pull it out working from the edge toward the middle as mentioned above. Buy or borrow a suction handle such as used for attaching to sheets of glass for carrying. They aren't that expensive and have a suction release lever.
Having said that, I am also of the opinion that you should go the insurance route if that is an option for you.
Dave
Fyrzowt is offline   Reply With Quote
Old 03-20-2007, 11:48 AM   #9
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Be careful using the hot melt glue method such as "The Ding Doctor"..you can over compensate when it doesn't release and can make things worse. It does work pulling them out though...I've used both methods and would have rather worked it from the inside out if I could have gotten to the area. Also be sure the area is perfectly clean if you are going to go with the suction cup method...fine particles of dust will scratch the clearcoat.
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 03-20-2007, 12:12 PM   #10
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have pulled out some basketball size dings with my ding king and have been pleased with the results. Not perfect, but about 90%.
Old 03-20-2007, 03:06 PM   #11
Don in E Texas's Avatar
I not only had a ding, I had a rather large ding - plus the lower part of the trailer had fallen off.
I found a local body shop that replaced both lower, front, sections using rear fenders off a 1987 ford PU truck (PERFECT curve fit!) and also took care of the huge dent (dent caused by me backing up blind and truck hit the front of the trailer). After dent was repaired, the entire front area was painted aluminum and brushed while still wet. Then clear coated. You can't tell it from brand new - and has lasted now for 4 years. Total cost? $600.00
Worked great for me.
Don in E Texas
Don in E Texas is offline   Reply With Quote
Old 06-08-2007, 09:48 AM   #12
A coconut fell on the front of the roof of my Safari when we were in Mazatlan. I think I can get at the dent and will try pushing it out from the inside, slowly. If that doesn't work, I will try the dent puller idea, again slowly and let everyone know the results.
handn is offline   Reply With Quote
Old 06-08-2007, 10:00 AM   #13
Fyrzowt's Avatar
2000 25' Safari
Images: 8
I watched a body shop friend fix a small dent on my car. He was able to access it from the under side. Working from the outer part of the dent in a circular fashion toward the center, he slowly pushed it out with a smooth tool, no paint damage. Don't try to push it all out at once.
Dave
Old 06-08-2007, 10:01 AM   #14
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
What the heck is going on here?
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 01:48 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 12 07-30-2009 07:14 AM
Dent repair options automatik Ribs, Skins & Rivets 11 11-03-2006 03:23 PM
Dent removel - two methods j54mark Ribs, Skins & Rivets 13 04-18-2003 11:52 AM
Dent Repair Jim W Ribs, Skins & Rivets 3 05-07-2002 11:43 AM
