Old 02-17-2009, 04:09 PM   #1
1958 22' Caravanner
Pueblo West , Colorado
Damage repair
I have a 58 flying Cloud and the front panels are ripped. Previous owner wasn't very careful backing it up. How is the best way to repair these panels? I hate to try and pull off the old panels and redo the whole thing. Do they make new panels for it?
Ron
Ron Banks is offline   Reply With Quote
Old 02-17-2009, 04:15 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Believe it or not panel replacement is really the only option. How many are ripped, a picture is helpful.
Old 02-17-2009, 04:56 PM   #3
soldiermedic's Avatar
Florissant , USA
Afraid that Aerowood is spot on. You need to replace that front panel. I am having to do it on my 53 Flying cloud. Fortunate for you, you are in the Mecca of vintage airstream restoration (Colorado). You can't throw a rivet set too far without hitting someone who has done it before. Lots of help for you.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-17-2009, 05:51 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Panel replacement separates the men from the boys. I, unfortuneatly, am a member of the latter. But from my view from the bleachers the acid test is 3 levels of expertise: flat panel, simple curve, and the pizza resitance compound curve. Panels are available from AS for thier weight in gold, but can be made from aluminum sheets. The compound curve (bendy in 2 directions at once) needs someone with real know how and some specialized tools to fabricate.
Old 02-17-2009, 11:53 PM   #5
'58 was the first full year for the compound curved end caps if I remember right. I was quoted about $400 each piece for those ones. The lower panels at the corners are just flat pieces wrapped from the side to the back. That should be a much less expensive part. There are some really good threads on this in the exterior restorations forum under "ribs, skin and rivets".
I think Soldiermedic is right about you being in a good location for that type of problem. You can see where most people live if you look below their name in the post, and you can search the member list by area to locate those close to you.
Good luck!
VIKING is offline   Reply With Quote
Old 02-19-2009, 05:02 AM   #6
1958 22' Caravanner
Guys, I hope this is not a dumb question, but what is the difference between a end cap and the front panels?
Old 02-19-2009, 05:14 AM   #7
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
Ron, I know when I started our trailer repairs it took me for ever to figure out what they were calling the banana wrap.
The end cap it the roof area on each end of your trailer. The front panel is the area below your window area on the curves.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 02-19-2009, 05:42 AM   #8
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Southeast , Michigan
Images: 41
I hope your "rip" isn't as bad as this one that was for sale a few months ago! It makes me cringe. Story was it had a run in with a street sign, but how does a street sign damage the front of the trailer without the tow vehicle first flattening it?
Joe
WBCCI/VAC #702 & #6768
66Overlander is offline   Reply With Quote
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
Water damage repair adammoore Argosy Motorhomes 1 05-14-2008 05:53 PM
How do I repair water damage walls? juliesmama Member Introductions 1 09-05-2007 11:10 PM
I need to repair damage to the aluminum skin on my 345 MH. Mr. D Mechanics Corner - Engines, Transmission & More... 5 05-01-2007 07:46 AM
Body damage repair AccessMaster Airstream Motorhome Forums 0 08-14-2003 11:07 AM
