Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-19-2006, 10:04 AM   #1
Chopper
Profile:  1976 26' Argosy 26
St. Albert , Alberta
Cutting the Argy skin
Hi,
I'm about to put enlarge the old hotwater tank opening and replace it with a "baggage panel door". How do I make a clean opening in the aluminum? I'm thinking that I can use tin snips to make the rough opening, then a small grinder to clean up the edges?
Cheers!
Chopper is offline   Reply With Quote
Old 09-19-2006, 10:17 AM   #2
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
From another post of mine in the past:
You will want to get a 12" clearance strap duplicator. This will let you accurately drill a rivet hole in new belly skin or banana wrap, so that the hole is located over the underlying hole in frame or skin that you want to rivet together. Go to http://www.aircraft-tool.com/ecatalog.htm and see .... darn, there's no page number. It's and Adobe Acrobat document. Click the binocular 'search' icon and enter: 62-12 -- You do want the strap duplicator for #30 twist drills since this is what you'll use most often (just ream out afterward with a #21 drill if setting a 5/32" rivet). This is the handiest tool ever and you can thank Forums member markdoane from Minnetonka for the idea.
Snipping metal shears (you won't want scissor type metal shears from the hardware store!). In the http://www.aircraft-tool.com/ecatalog.htm catalog again, search on: Jilson Supersnip -- I haven't needed a 2nd blade by any means -- the original is enough. I also don't know enough to recommend the cheaper one on the same page. These shears are time consuming but reasonable unless you have air tools already. I would use a hand tool like this for such a small job (ie, a single trailer). You won't be asking "why not" on tin snips after you see the undistorted smooth edge these produce! Good tools make good trailers/aircraft!!
Old 09-19-2006, 10:41 AM   #3
Chopper
Thanks Canoestream
I should be searched harder before asking the question. I came upon your earlier post while I surfed around during my "coffee break". Really, this is work
Cheers!
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 06:33 PM
Kitchen sink Cutting board. Joan D'Andrea Cabinets, Counter Tops & Furnishings 1 11-07-2002 11:57 AM
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 1 06-01-2002 08:08 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
