Old 09-11-2016, 09:19 PM   #1
1962 19' Globetrotter
2001 31' Excella
Cutting Aluminum
I'm about to start a repair project and looking for thoughts on the best way to cut aluminum to shape before for a large patch. Thanks!
Craig is offline   Reply With Quote
Old 09-11-2016, 09:24 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I assume you are talking about aluminum sheet. Electric Shears (nippers) if you are going to be doing a fair amount of cutting. Harbor Freight shears work good.
Old 09-11-2016, 10:36 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
For large thicker aluminum sheets I have used a tool called a "nibbler". It basically nibbles out uniform notches.. You just carefully guide the tool along a clear line or arc guide and it just does a clean job with minimal edge lift/distortion.. There are hand type and electric. The electric will do an amazing job...less hand effort, but huge cost
Lift����
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-11-2016, 10:41 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Cutting Aluminum
For those with a steady hand a pneumatic cut off wheel is hard to beat.
A band saw with a narrow blade can work very well too.
Gradiens super tenui glacie.
Old 09-11-2016, 10:45 PM   #5
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I used the Harbor freight electric shear on my project they work great.
I also used the hand shear and the hand nibblers for tight areas .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 09-12-2016, 06:48 AM   #6
2001 31' Excella
Would a jigsaw work?
Old 09-12-2016, 07:48 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
be careful
Most of the suggestions you see here will leave you with an edge which won't look good and be difficult to work with to make it look good. Any...ANY....small "wobbles" and cut marks will show. Filing to an "edge" is hard. Just measure it and take it to someone who has a shear. Now, on a small patch you can get away with those other cutting tools.
Old 09-12-2016, 08:25 AM   #8
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Careful use of a bench-mounted belt/disk sander will smooth out the edges very nicely.
Lots of good advice about tools and techniques on these forums. Also many good demonstrations on YouTube.
youngpeck is online now   Reply With Quote
Old 09-12-2016, 08:37 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
Yes, but in my experience hard to cut with a jigsaw without a lot of vibration.
Old 09-12-2016, 09:20 AM   #10
youngpeck's Avatar
1976 25' Caravanner
You can spring-clamp sheet metal (ie., aluminum) onto a piece of plywood. Keeps it from bouncing around as you cut it. Better yet, sandwich it between two pieces of clamped plywood. Variations on this procedure are many.
Old 09-12-2016, 09:38 AM   #11
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I opened up the ceiling under a light in my Safari with a Harbor Freight pneumatic nibbler. It worked great. It does leave a rough edge, so if the edge is going to show you would have to smooth it with one of the techniques mentioned earlier here. In my case, the light covered it up, so no worries.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-12-2016, 10:12 AM   #12
Rich and Kat
AIRHEDS's Avatar
Virginia ... near ... , Washington, D.C.
Hilti and others make circular saw blades for cutting non-Ferrous metal as well as steel. Never used one but they look cool. I will get a blade for my Festool Kapex (chop saw) but haven't needed it yet.
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF
Save
AIRHEDS is offline   Reply With Quote
Old 09-12-2016, 10:29 AM   #13
ericpeltier's Avatar
Superior , Colorado
I have a red 10" sawblade I got at Home Depot, brand is escaping me, for non-ferrous cutting. In my tablesaw it cuts thick aluminum like buttah. It's astounding. I need to try it on the 0.032 aluminum I have.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
ericpeltier is offline   Reply With Quote
Old 09-12-2016, 11:18 AM   #14
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I use this
Alcoa Aluminum Cutting Back wheel interested Our Community 3 01-10-2009 11:25 AM
quick question on aluminum cutting wannaroam Ribs, Skins & Rivets 15 01-01-2007 08:23 AM
Cutting Aluminum Stinky Ribs, Skins & Rivets 23 04-09-2006 03:15 PM
cutting Aluminum Patterns donf Ribs, Skins & Rivets 5 01-18-2006 10:22 AM
Cutting Holes in Aluminum somefun General Interior Topics 6 07-25-2005 08:34 AM
