Old 09-12-2016, 11:29 AM   #15
LifeIsRiveting's Avatar
1976 25' Caravanner
Overland Park , Kansas
Originally Posted by Aerowood View Post
I use this
Drool...
Also, for most aluminum sheet thickness that would be used on an Airstream you can score a line with a knife a few times and then it will fracture when you bend it back and forth a bit. You can get a pretty clean edge in most cases but it is really only viable for straight cuts.
Aerowood probably has some additional advice on this topic of scoring aluminum.
LifeIsRiveting is offline   Reply With Quote
Old 09-12-2016, 11:58 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Originally Posted by Lumatic View Post
Yes, but in my experience hard to cut with a jigsaw without a lot of vibration.
Mount the edge you are cutting very close to the edge of a bench to mitigate this.
Gradiens super tenui glacie.
Old 09-12-2016, 01:30 PM   #17
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by ericpeltier View Post
I have a red 10" sawblade I got at Home Depot, brand is escaping me, for non-ferrous cutting. In my tablesaw it cuts thick aluminum like buttah. It's astounding. I need to try it on the 0.032 aluminum I have.
I have found that a table saw will work well for straight cuts in aluminum sheet. Use a zero clearance throat insert and make sure the aluminum sheet can't slip under the fence. You can either clamp a piece of angle aluminum to the fence and run the aluminum on top of it, or run it through with a piece of scrap plywood underneath the aluminum. I find that it's also helpful to run a piece of wood on top of the aluminum with the blade set below the top surface of the wood. This helps to keep the aluminum from vibrating and reduces the number of aluminum chips being thrown back at you.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 09-12-2016, 02:17 PM   #18
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Originally Posted by LifeIsRiveting View Post
Drool...
Well, as a matter if fact I do, I have always called it a Skin Knife. Its made from a file
Old 09-12-2016, 02:49 PM   #19
1976 25' Caravanner
Ah yes, thanks for the trade secret!
That is exactly the image that was burned into my brain. Although I've successfully used the scoring method with various shaped razor blades the skin knife looked much more robust. I remember googling "skin knife" half a year ago and coming up with nothing. It's not often that a google search comes up empty handed, haha.
Any suggestions as to the shape of the modified file?
Old 09-12-2016, 03:03 PM   #20
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have not heard of a skin knife before and have not used the score method on aluminum. I have used a utility knife on sheet metal and it works.
Old 09-12-2016, 03:19 PM   #21
1979 23' Safari
Wayland , New York
How big are your patches? I used the utility knife scribe method for some small pieces. Works if you're careful. Most other stuff that appearance mattered I had cut on a shear at the metal supplier. Couple bucks a cut was well worth it.
Old 09-12-2016, 04:31 PM   #22
Aerowood's Avatar
Arvada , Colorado
More or less just a 90 degree hook on the end with the thickness reduced to around 1/32" thick. The picture shown was of me cutting off about a 1/4" of materiel off of a 11' long side panel. I finished it up with a vixen file. The whole process took about 30 minutes.
I have used this method in the past making long skin cuts on aircraft skin and not damage the underlying structure.
Old 09-12-2016, 06:39 PM   #23
1974 25' Tradewind
Calgary , Alberta
For free-hand cutting, these offset Wiss snips are great.
They make mirror-image tools for left/straight and right/straight cutting, and the blade offset allows you to cut way into a sheet without having the sheet get in the way of the snips or your hands. If you take care to not close up the snips all the way as you're cutting, then it does not overly distort the edge so that you can easily clean it up with a straight mill file.
Alumineer is offline   Reply With Quote
Old 09-12-2016, 08:29 PM   #24
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Cutting Aluminum
Band saw.....
http://i245.photobucket.com/albums/g...pslpykzc5n.jpg
http://i245.photobucket.com/albums/g...psbqwhxp28.jpg
Cut off wheel....
http://i245.photobucket.com/albums/g...g/DSCN1104.jpg
Old 09-12-2016, 08:40 PM   #25
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Wow nice map
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 09-13-2016, 11:20 AM   #26
1976 25' Caravanner
Nice work J. Morgan! How many TPI for that band saw blade?
Old 09-13-2016, 11:26 AM   #27
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I've made some cool stuff from old files. Now I'm going to make one of these. Thank you Aerowood!
Dingo Girl is offline   Reply With Quote
Old 09-13-2016, 08:25 PM   #28
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Cutting Aluminum
It has been years since My son cut that but I think it was a 28 tpi blade.
I know it was a 1/4" wide.
Alcoa Aluminum Cutting Back wheel interested Our Community 3 01-10-2009 11:25 AM
quick question on aluminum cutting wannaroam Ribs, Skins & Rivets 15 01-01-2007 08:23 AM
Cutting Aluminum Stinky Ribs, Skins & Rivets 23 04-09-2006 03:15 PM
cutting Aluminum Patterns donf Ribs, Skins & Rivets 5 01-18-2006 10:22 AM
Cutting Holes in Aluminum somefun General Interior Topics 6 07-25-2005 08:34 AM
