Old 11-29-2009, 03:27 PM   #85
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
My Question? Do I make the hole larger or just drill out the areas that are needed. Both sides of the lock are identical and mate in the middle including the long thin piece.
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 11-29-2009, 06:22 PM   #86
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Its an apples or oranges thing. I would just remove the minimum amount of aluminum to make it work.
Kip
Old 11-30-2009, 07:33 AM   #87
1961 16' Bambi
Mancos , Colorado
Thanks Kip, that's what I'll try then.
AirstreamGypsy
___________
My Earthship
Old 11-30-2009, 07:38 AM   #88
1961 16' Bambi
Mancos , Colorado
Originally Posted by AirstreamGypsy View Post
I figured while the Bambi is disemboweled I thought I take it further and replace the shower pan that I have repaired twice.
http://www.airforums.com/forums/atta...0&d=1248566431
Oh, and I'm going to reinstall the shower pan after finishing the form for it. Can then take my time making a new one (fiberglass also)
AirstreamGypsy
___________
My Earthship
Old 11-30-2009, 07:56 AM   #89
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Suzanne
Are you a Fiberglass expert? We are looking for someone to do a presentation on Fiberglass at the Vintage Restoration rally....
Hope you are doing well...
Ken J.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-30-2009, 09:02 AM   #90
1961 16' Bambi
Mancos , Colorado
Expert!? That's like saying wo-ork (Maynard G. Krebs). Not hardly. But let's see after the next two months if I am capable. If so, I'll be glad to exhibit the process.
Doing great thanks!
AirstreamGypsy
___________
My Earthship
Old 12-04-2009, 05:22 PM   #91
1961 16' Bambi
Mancos , Colorado
After a bit of deliberation, I have decided to get Vintage Trailer Supply's DEADBOLT instead of the free one I have. Why? Because then I don't have to put any new holes in the Airstream door. And it is not keyed on both sides. That is probably why it doesn't have the extra (whatever they are called) extrusions, just the single pin going through.
I also was finally able to remove the coving in the toilet area. :-) Had to take out the toilet anyway in order to put in the new vinyl. NO MORE SILICONE I hope. I will also put a lot less plumbers putty behind the coving as well. Jeepers it's like cement. Of course it comes out a little better if you remember to take out all the screws.
Here is the vinyl flooring.
Do you need to put in a new ring for the toilet every time you take it out?
ID:	92037   Click image for larger version
AirstreamGypsy
___________
My Earthship
Old 12-04-2009, 05:26 PM   #92
1961 16' Bambi
Mancos , Colorado
duh.
Toilet and coving and vinyl removed.
AirstreamGypsy
___________
My Earthship
Old 12-04-2009, 05:27 PM   #93
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Glad you are making progress. Look forward to pics. [on edit, I see them now]
I would.
Vaughan
Old 12-04-2009, 05:29 PM   #94
1961 16' Bambi
Mancos , Colorado
I should know the answer to that question as my son is a plumber.
Thanks!
AirstreamGypsy
___________
My Earthship
Old 12-04-2009, 08:37 PM   #95
1983 34' Excella
1967 24' Tradewind
Images: 32
Of course it's easy for me to say I would. I have a new ring under the sink right now that I bought planning to pull out the carpet in my Excella but got delayed by other things. Now the seat has started cracking, so I guess I will replace the throne when I do the flooring.
That means I should have an extra one since a new toilet will have one. Talk about be prepared.
Vaughan
Old 12-05-2009, 07:59 AM   #96
1961 16' Bambi
Mancos , Colorado
Cracked... not good. extra ring and being prepared? Good.
AirstreamGypsy
___________
My Earthship
Old 12-05-2009, 08:08 AM   #97
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
As an extra precaution, I would put a coat or three of polyurethane over the wood before applying the new flooring material. Best to be prepared since you've come this far.
Your progress looks great and let us know how the deadbolt installation went. Pix too, of course.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-05-2009, 08:08 AM   #98
1961 16' Bambi
Mancos , Colorado
Should probably put some of these posts elsewhere but in my mind these repairs are all because of the replacement of the exterior panel, so here they stay.
Zep started this when we were replacing the panel. I'm finally getting around to finishing it.
Wheel well, new insulation and cover. Trouble is I cannot remember if I am supposed to attach the cover to the trailer wall with screws/rivets or just use the silver tape and tape it to the wall or glue it, (which I don't really want to do because then it will never come off)
You'll note that there is a rail laying across the top, not attached, that i can attach to the trailer wall and the cover.
Name:	wheel well 1.jpg
ID:	92064   Click image for larger version
Name:	wheel well 2.jpg
Name:	wheel well cover.jpg
AirstreamGypsy
___________
My Earthship
bent door kcbrady Doors & Locks 3 11-28-2006 05:04 AM
67 ambassador entry door bent jonvon General Interior Topics 3 08-03-2006 04:11 PM
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 10:44 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
