07-14-2008, 02:45 PM
#41
1961 16' Bambi
Mancos
Originally Posted by GT1963
Oh me too me too....believe it or not - way up in the 2005's they made a suicide door.
and now I have found a piece of mind fix for the door - super!!!
So Yes Please I would love to get a template - I will PM you.
GT1963,
Now you have THREE Airstreams, I'm green with envy
AirstreamGypsy
___________
Charter Member FCU • WBCCI 1818 • CP(Courtesy Parking) • Wi-Fi
My Earthship
07-14-2008, 02:54 PM
#42
2005 22' International CCD
Buckhorn
, Ontario
Originally Posted by AirstreamGypsy
GT1963,
SHHHHH!!!Peter does not know yet. It is a huge surprise for our Silver Wedding Anniversary....and they say that women can not keep secrets or do anything big without their husbands knowing -
See.... he let me tow solo so the sky was the limit.
And let this be a lesson to all you restorers out their - your wives can only wait so long before she just has to have a fully functional trailer
And to all those wives out their - never let your husband sell your trailer on you to begin with - hmmm MoonBeam comes to mind for me...
But yes in all seriousness - we have three trailers and a fourth spread around our property in sheds without the shell
We will be making arrangements to sell off one of the Vintage units and unloading the massess of parts we have accumulated.
We are keeping the 19' GT and will continue with her restoration when we can - but it will be a hobby and not a burden. Once finished we will then evaluate the situation and quite possibly will be selling the 19' or travel a bit with her to some Vintage Rallies.
Just never know what is around the corner.
07-14-2008, 03:06 PM
#43
1971 21' Globetrotter
Arvada
S######, can you get some more pictures of the door damage and fuselage dent. I was thinking that if you could get the door up to me I could fix it over the winter months.
07-22-2008, 10:24 AM
#44
1961 16' Bambi
Mancos
Kip,
That idea is sounding better. But I'm hoping for a shorter duration. :-) Deadhorse rally in Feb!!!!!!
I need to find out which aluminum to buy if I need to replace the side wall.
Thanks, I've PM'd you.
AirstreamGypsy
___________
My Earthship
04-15-2009, 08:45 PM
#45
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Replacing the skin and stringer
The biggest obstacle was the lower door hinge attachment. Very strange rivets, heads shaped like Maddonna's bra, but it turned out they were 5/32" solid rivets that were easy to drill out. You can see the aluminum backing plate in the left photo. This plate was very tenuously held onto the ribs, but was mostly in place due to the rivets through the outer skin.
Here's the steps we went through:
1. Remove inside closets, partions, and partion rails.
2. Remove fiberboard wheel well covers.
3. Remove door hinge pins and remove door.
4. Drill out lower hinge rivets.
5. Drill out all inside skin and outside skin rivets.
6. Remove lower outer skin.
7. Remove lower inside skin.
8. Use outside skin as template to match drill and shape new skin. Don't match drill all holes on the bench--consider using the joints where other skins are on top to match drill with the new skin in place on the trailer. Cut the new skin to provide a very slight overlap of skin to the door frame.
9. Reinstall the hinge backing plate using flush solid rivets.
10. Once all the holes are checked across the entire skin (in place), apply Vulkem to appropriate surfaces and put the skin in permanently. Continually monitor the placement of the ribs and the alignment of the inside skin holes to the ribs. Pay close attention to gaps and joints along the wheel well and the "C" channel immediately adjacent. It may require significant gasket, eg, maybe some butyl tape and certainly a liberal application of Vulkem.
11. File the skin down to match the door frame (there was a very slight curve in the door frame, about 1/16" over the height of the lower skin, that made the skin proud of the frame (this is the desired condition, as it can be fixed with a little filing).
12. Replace the insulation.
13. Pop rivet the inside skin to the ribs.
14. Done. About 7 hours for steps 9-13. About 6 hours for steps 3-8.
A note here about the stringer. It was a very flimsy "C" channel of 0.032. You can see in the photos the significant deformation of the flanges and especially the web. It was a real shock to find that the inside flange of the stringer was not attached in any way to the inside skin. This was also true for a similar stringer about 18" lower in the same wall. The outside flange was only attached with 5 or so solid rivets, very flimsy indeed. Also, the inner skin joint line was about 3/4" above the outer skin line.
The stringer was replaced with a "Z" channel made up from two 0.040 stringers that had been previously fabricated by AEROWOOD. These were for larger 70s Airstreams so they were 1-34" wide and the Bambi needed 1-1/2" width. Two of these larger stringers were cut down, one flange off of each one, then riveted together with a double web to make a new "Z" channel. The "Z" provided sufficient offset so that the outer and inner horizontal skin joints each fell on a flange, so the inner skin is now firmly attached to the stringer. The shell is now significantly stronger along the skin joint and very flat.
Zep
04-15-2009, 09:17 PM
#46
1973 23' Safari
1977 23' Safari
Palmer Lake
fixing the door curve
The Bambi door is really two jobs, the outside main door and then the door within a door. Each has a rib that needs to be re-curved. The nice thing about this door is that all the solid rivets can be accessed, drilled out, and re-bucked without removing any inside skins. Here's the steps we took to put the proper curve back in the door:
1. Made a template of the shell shape immediately adjacent to the door using 1/8" luan.
2. Cut a female 1/2" plywood fixture to match that shape.
3. Clamped the plywood to the door to see if the door would follow the curve of the plywood. Yes!
4. Removed the solid rivets from 18" below the lockset to 24" above the lockset. Same for the pop rivets on the inside door skin.
5. Removed the plywood and re-clamped it to the door, but this time with shims top and bottom to over-bend the door slightly. This was an experiment, starting with 1/8" shims and finally settling on 1/2" inch at the top and 3/8" at the bottom, with a 1/4" shim on the inside of the door for the clamps on that side.
6. Added some screw bucks to the plywood so it could be attached to the door and the door closed to check the fit. Surprisingly, just 5 #6 by 1" screws were able to hold the fixture on the door. It seemed that there was way too much force in the clamps for this to work, but it did.
7. Replace the rivets with the door now clamped to the fixture (screws went through the existing rivet holes, so they had to be removed and clamps used for this step). This required some innovative thinking on where the fixture was clamped, so as to avoid compressing the skin permanently.
8. Similar steps for the door-within-a-door.
9. Total elapsed time was about 6 hours.
For all the careful fitting of the outer door, it just didn't take the right shape until the inner door was also re-curved. It was immediately apparent that this fixed 90% of the remiaing curve error. With one additional tweak to the outer door (just clamping with shims, no work on the rivets), the curve was exact. In the photos below, you can see we used a 2x10 as the form for the inner door.
The final product is not perfect. The lockset is still canted slightly, although there is no noticeable crink in the door skin. Maybe there will be additional "fixing" at the 4CU maintenance rally.
Zep
04-15-2009, 09:23 PM
#47
Arvada
Good work Zep. I wish I could have been there to give you a hand. Did you get Sxxxxxe to buck for you?
Kip
04-15-2009, 09:29 PM
#48
1973 23' Safari
1977 23' Safari
Palmer Lake
Originally Posted by Aerowood
Good work Zep. I wish I could have been there to give you a hand. Did you get Sxxxxxe to buck for you? Kip
You bet. She picked up the technique a lot faster than I did. I just had to admonish her once on the right radio calls--"ready" and "good." We never had to use "set."
The best thing about the second day was she proved that it's not just me that Vulkem wants to stick to...
She is the most amazing mechanical girl (uh-oh, dope slap). You only have to think the thought and she hands you the right tool or puts the part in the right place in the right orientation. A natural born mechanic. You couldn't do better than to have her working on your airplanes...
Zep
04-16-2009, 03:44 PM
#49
1961 16' Bambi
Mancos
Thank you for the kind words! And all the hard work! I would never have gotten something like this done myself. (major coward)
I'm so glad Zep posted, as he is mush better at detailing the repairs than I.
What more can I say about the repairs, I'm thrilled. But I can post some additional photos.
A horrible corner...
Panel installation... sorry about the lighting. We were working in an unheated barn with minimal electricity and I forgot to change the flash.
AirstreamGypsy
___________
My Earthship
04-16-2009, 03:49 PM
#50
1961 16' Bambi
Mancos
Kip
Kip, we missed you! I'm sure it would have gone much faster with your help. I sure did learn a lot though. I can now buck rivets and am not so frightened of drilling them out in the first place.
AirstreamGypsy
___________
My Earthship
04-17-2009, 08:17 AM
#51
1961 16' Bambi
Mancos
New Panel in Daylight
Thought you all might like to see how the panel looks in daylight.
And the all important seam. It may not look like much but this is the aft edge of the door frame. It is an angled and smooth connection between the panel and the frame of the door. Zep filed this after it was on the airstream. We had left a good deal of overlap to begin with. At least 1/8".
AirstreamGypsy
___________
My Earthship
04-17-2009, 08:28 AM
#52
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
That is excellent!! Now its my turn, I'm next. Pick me.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
04-17-2009, 08:34 AM
#53
2002 25' Safari
Dewey
You guys did a great job on the side and the door. I remember how it looked last summer when we stopped by your place. You should be very happy to have your Bambi on the road again. C U soon...
Now to put all the stuff back inside.
Richard
04-17-2009, 08:37 AM
#54
1973 23' Safari
1977 23' Safari
Palmer Lake
Brad,
The skin along your side is probably quite a bit longer than on the Bambi. It was lucky that the Bambi skin was only 41", so we could get a 4'x4' sheet of 2023-T3 shipped for only $16 (I think the piece was about $80). Anything bigger would have cost $100+ to ship (but they can roll the sheet and still ship something bigger without having to go freight). We used 0.040, which is really nice to work with, a better "feel" than 0.032.
The other consideration is that we put the skin on with solid rivets--the inside partitions were removed so we could take out the inside skin. The job can be done from one side, but then you're stuck with Olympics. They look great if they are installed and shaved properly, and it would probably take a lot less time. On the other hand, dealing with the stringer (is yours bent, or do you just have skin damage?) would be difficult, but not impossible.
If you ordered today, you could probably have the skin in your hands by Wednesday. Airparts Inc. Homepage I know Luke is bringing a shaver. But I don't have enough Olmpics on hand, you'd have to get those, too.
Zep
#55
1961 16' Bambi
Mancos
Thanks! - and - Can't Wait!
However, you should see the inside now:-(
AirstreamGypsy
___________
My Earthship
04-17-2009, 08:39 AM
#56
1961 16' Bambi
Mancos
Oh, and I forgot to mention. I just crashed my truck. Spun out in the snow. Have no idea yet wether they will "total" it or not. I WILL FIND A WAY TO THE RALLY WITH BAMBI
AirstreamGypsy
___________
My Earthship
04-17-2009, 08:42 AM
#57
1959 24' Tradewind
Phoenix
Zep ~
First of all, you do nice work but I've always known that. I have a shaver but not an indoor place to work on it. I don't think my stringer is bent and I know my door has lost some of its curvature from slamming open. I really need a big shop, big time.
FF
04-17-2009, 08:44 AM
#58
1959 24' Tradewind
Phoenix
Oh no!!! Geez, its one thing after another for you. Looking forward to seeing you in Alb. so I really hope you can make it.
BTW - the toilet arrived and I just haven't made the time to examine it but I know it will serve me well. If parts are needed, I hope they are still available.
Ff
04-17-2009, 08:53 AM
#59
Arvada
My God S with a Z, I hope you are OK, trucks can be replaced.
I am still in Abbotsford BC and my flight home today has been canceled due to storm in Denver, chances are slim for tomorrow mayby Sunday I can get home.
04-17-2009, 09:10 AM
#60
1961 16' Bambi
Mancos
Ff
I'm sure you can get it working.
I am worried about my personal KARMA. It seems a bit out of whack.
AirstreamGypsy
___________
My Earthship
