Old 10-13-2011, 10:48 AM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
hold down plate ??
If the front interior walls were taken off could the hold down plate have a 90 degree angle and be bolted (self tapping bolts) down the the crossmember that goes between the A-frame?
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 10-13-2011, 10:52 AM   #16
If you take the interior panel off that's below the front window, all you will see is a floor channel and some wires. You will not see the frame at all.
Secondly, since that are receives a lot of punishment, I really don't think bolting a plate to the frame, will lasy very long.
Installing a plate from the outside, would take about 4 hours, as long as all the equipment was available.
Old 10-13-2011, 11:17 AM   #17
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
To spread the stress out, welding to the frame would likely be better. I have never had one appear in that area but a question posed to the engineering department at Jackson Center might get you a authorized answer.
Skin & Corrosion Updates silverhound Clearcoat, Exterior Paint & Trim 39 10-11-2012 11:01 AM
Looking for advice on interior skin of 74 Safari Eric H General Interior Topics 2 09-05-2011 04:39 PM
Cracks in refrigerator lining jacqueg Refrigerators 6 06-30-2011 02:47 PM
sticky black tape between interior skin & frame? clipperguy Ribs, Skins & Rivets 1 03-21-2011 04:00 AM
Rear Skin Panel john1dup Ribs, Skins & Rivets 1 03-12-2011 11:02 AM
