Old 04-09-2014, 07:25 AM   #15
1994 34' Excella
Kalamazoo , Michigan
Patch/Reinforcement over door.
Originally Posted by SSChanger View Post
I've got a crack developing at the 1 o'clock position, moving from the door toward the roof. It started at about 4", and I drilled a 1/8" hole in the end of it last year to stop it. Since then, it has continued another 1/2" above the hole.
I've sealed it with clear silicone to prevent any sort of leakage. Any tips on what might be done with this? Your ideas are appreciated!
The door on my 94 Excella 34 has a rather well done patch or reinforcement over the entry door that extends at about a 45 deg. angle upwards at both corners to above the gutter line. I am presuming that this is a result of some cracking like what is mentioned in this thread. I have checked pretty carefully for any other signs of deflection/separation in the front end, and there is none evident, but I may not be looking in the right places.
Any thoughts/tips/advice? I will post a picture as soon as I figure out how to do that.
Thanks...
TomS is offline   Reply With Quote
Old 04-12-2014, 08:35 AM   #16
1994 34' Excella
Name:	ImageUploadedByAirstream Forums1397313288.566319.jpg
Ahhh...there we go! Note patch above door...
Old 08-08-2014, 05:43 AM   #17
1994 34' Excella
Name:	ImageUploadedByAirstream Forums1407498224.445516.jpg
Old 08-09-2014, 02:59 PM   #18
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Tom... That should do it! Sure looks like the best fix available to strengthen the area!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-09-2014, 03:28 PM   #19
Originally Posted by TomS View Post
Attachment 218596
I have seen that type crack hundreds of times.
The causes?
Excessive rated tow vehicle.
Excessive rated torsion bars.
Lack of proper running gear balance.
Excessive rated trailer tires, with excessive air pressure.
One or more of the above have always been the problem, without exception.
Old 08-10-2014, 03:54 PM   #20
falcon-N-Air's Avatar
1995 34' Excella
Dalton , Georgia
Tom, this is exactly what the Doctor ordered for our Excella. I am checking on the Aluminum now.
Eric
Eric & Michelle Shuler
1995 34' Excella
2003 Chevrolet Silverado Z71
WBCCI # 7096
falcon-N-Air is offline   Reply With Quote
Old 08-13-2014, 11:57 AM   #21
Eric
When a crack, such as this one appears, the question always becomes "WHY".
If there was a error in the engineering, then that crack would happen many many times.
When a crack does appear that is extreme rare, then one must ask themselves "what caused that to happen".
Of course blaming the manufacturer, is always the easy way to go. But in this case, it's totally incorrect.
Check out all the things I mentioned above, and an answer or two, will surface.
Old 08-15-2014, 04:34 AM   #22
1995 34' Excella
Dalton , Georgia
Thanks Andy, I am going to follow your advice about adding Rivets between the Awning rail and the belt line. Going to cover the crack first with the Patch.
1995 34' Excella
WBCCI # 7096
Old 08-15-2014, 06:03 AM   #23
1981 31' Excella II
New Market , Alabama
Are the corners above the door sharper on the newer trailers? I don't remember mine being that square. The sharper those corners on the door opening the more stress you will see.
Perry
Exterior Door Hinges LKappenman Doors & Locks 25 11-09-2012 11:30 AM
Screen Door Crack azflycaster Doors & Locks 14 04-13-2007 09:04 PM
Exterior crack above door Teacher3rd Ribs, Skins & Rivets 24 02-04-2007 12:48 AM
Exterior Door Trim Lumatic Doors & Locks 0 01-06-2007 09:10 PM
Exterior Door Movement Action Doors & Locks 0 05-20-2002 03:07 PM
