Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-15-2013, 02:46 PM   #1
2005 16' International CCD
Cost to scrape and reseal
I have my 2005 16ft Bambi in for some miscellaneous repairs and the repair place says I also need to have the outside resealed. I haven't had any leaks but I also don't know if this is something that needs to be done after some number of years as general maintenance. They quote me a price of $770.00.
So, two questions. 1) is this something that needs to be done on a regular basis, and 2) how much should I pay for this?
BambiBirder is offline   Reply With Quote
Old 08-15-2013, 03:14 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
HIJACK - don't trust your Airstream to an unknown shop. The people who will do it wrong (from ignorance) or really effit up (malice & desire to rip you off) outnumber the honest who will totally nitpick the job. And this is one job you want to be done by a nitpicker! Assume they're billing you $65 per hour for the mechanic's time plus materials... that seems to be about 11 hours. Which for me wouldn't be enough time to do even a Bambi, but I'm not a pro so I work much slower than a professional can. Price is pricy but "reasonable". Or you can find a shade tree, get a couple of ladders and totally blow weekend - and spend $100 or less in materials and pocket the rest PLUS you know how well the work was done. (of course if your nickname is "shakey" and you can't make a bead of caulk to save your life - or even lay out blue painters tape as a guideline - then paying someone to do a neat job is worthwhile.)
Paula
Old 08-15-2013, 03:26 PM   #3
Thanks Paula, good to know. The quote came from a certified Airstream dealer/repair shop so I assume they know what they're doing. Doing it myself is not a good option, lack of time and let's just say I have a tendency to color outside the lines.
Old 08-15-2013, 03:47 PM   #4
"Cloudsplitter"
Thumbs up
I would have them do a pressure leak test so you can see the leaks, instead of just taking their word for it.
Give Soldiermedic a PM, he can explain it much better than I.
Old 08-15-2013, 08:23 PM   #5
Oh Robert - I SO agree with a pressure test - concentrate on finding and fixing REAL problems, not just caulking everything good, bad or ugly. Leaks happen in the oddest places (TV antenna) and travel 4 feet before revealing the ugly evidence.
Paula
Old 08-16-2013, 07:07 AM   #6
Mantua , Ohio
Yes, resealing is a normal maintenance item. If we all did this at least every other year most leaks would be found before major damage is done. Just waiting for a leak to show itself can result in major repair costs. Jim
Old 08-16-2013, 08:27 AM   #7
Thanks Jim, appreciate the response. Sounds like a preventive measure even if leaks are not currently present.
Old 08-16-2013, 08:36 AM   #8
"Cloudsplitter"
A common leak source...
....Get up on the roof and inspect all the vents. It will become very evident what may be needed.
Your avatar?
