Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 06-28-2004, 09:36 AM   #1
breakaway
breakaway's Avatar
Profile:  1989 29' Excella
Bloomfield Hills , Michigan
Images: 20
Cost to fix DENT?
What would it cost to fix this dent? I’m thinking about buying this Airstream but was wondering what it would take to fix this dent.
breakaway is offline   Reply With Quote
Old 06-28-2004, 10:26 AM   #2
RichardT
RichardT's Avatar
Profile:
I think alot of it could be pulled out (not the parts on seam) and make it look better, check other posts for removing dents.
But to have it fixed I think runs about $800.00 per segment and less I am sure for the center one.
Check Inland to find out if they have the segments you need and you could do it yourself for a lot less.
Check that area for leaks as the way it looks, if it doesnt leak now, it probably will eventually.
RichardT is offline   Reply With Quote
Old 06-28-2004, 10:46 AM   #3
j54mark
Profile:
$1,000 per segment is closer to the mark. Of course, it depends upon where it is done. I count three, possibly four segments damaged. Only two, however, can be readily seen from the ground.
Mark
Dent Removal uwe Ribs, Skins & Rivets 7 11-14-2004 10:15 AM
What did it cost new? Stefrobrts Trailer Values 6 06-14-2004 02:34 PM
thanks for the advice on the dent wayne.yl Ribs, Skins & Rivets 8 11-07-2003 06:23 AM
The dent, another question... Kistler Our Community 1 08-24-2003 01:40 PM
Dent Pullers wagsrp Ribs, Skins & Rivets 8 10-18-2002 11:37 PM
test
