Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-26-2008, 05:20 AM   #29
Airstreamer67
Airstreamer67's Avatar
Profile:
Wow, doesn't Airstream water-test those units anymore? What does $60K buy us nowadays?
Airstreamer67 is offline   Reply With Quote
Old 05-26-2008, 09:42 PM   #30
Bambi_Bandit
Bambi_Bandit's Avatar
Profile:  2008 27' International CCD FB
Blessing or Curse?
Originally Posted by Bambi_Bandit
As I sit here at the RV park in Sikeston, the storm moves a bit further south and east than early predictions...I get heavy rain mixed with - you guessed it, hail...
Sounds like pea sized, but the storms not done yet. Will have to check that in the morning....
Oh yeah - to add insult to injury - I find 2 leaks... I guess since the trailer is always stored under cover, and we've never been out in a heavy rain since we've bought it, we never knew...
Started to see a STREAM running down the front bedroom screen, down the wall, then onto the bed platform and bed on the curb side...Matress and platform are getting soaked...
Ran outside in the RAIN and light HAIL to see what the source could be.. found the top roadside panel and center panel (where AIRSTREAM is written) has a 1/2 gap... no silkaflex, just open gap...
The only thing I happened to have in my toolbox was an old tube of clear silicon.
Anyone ever try standing on the front frame (and Hensley strut) in rain and hail, attempting to towel dry an area (with little results) only to put some caulk down on wet aluminum?
Leak reduced to 30% of what it was before... I'll have to live with that for now.
Also found the rear curbside wrap around bottom track wet. Don't see any water track or running down the inside of the glass, but water is collecting on the bottom track... ARG!!!
I need a drink....I tall drink...
The heavy rains was a blessing or curse - depends on how you look at it. It turns out we never had Cosmo in the rain as strong as last night, and thus we found (7) SEVEN leaks.
  1. One on the window above the bed as mentioned above
  2. One INSIDE the walls between the roadside wrap window and the curbside wall window. I could hear the "drip drip" of water hitting wet insulation, and water seeping out the inside panels
  3. One on the Streetside window above the sofa lounge
  4. One on rear curbside wrap window
  5. One on the rear roadside wrap window
  6. 2 on the rear center window.
Then, today, on the way to JC thru the rains in Illinois, I have a leak from the fantasitc fan above the bed, AND a leak coming from the panel above the bed towards the end of the bed by one of the halogen lights...
I guess that makes (9) total leaks that JC will have to address when I'm here!!
I'm sitting at the terra port now - semi-hoping for rain to come hard so I can show Airstream the leaks in the morning.....
Kevin & Prim Li
Bandit the Siberian Husky & "G" the Min-Pin
Cosmo the Custom 2008 27FB Intl CCD
2008 Ford F-250 King Ranch Diesel 4x4 AKA "The King"
WBCCI # 11809
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 05-26-2008, 10:09 PM   #31
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
That many leaks is kind of surprising. I've had mine out and driven in some very hard rain and never experienced any leaks.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 05-26-2008, 10:35 PM   #32
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I had a mystery leak from one of my two fantastic fans while camping in Austin last July. Close inspection revealed a pin sized gap where the Vulkem was applied. ( by me, no less)
Apparently that was enough to cause a drip-drip-drip right above my bed...most annoying.
I feel for you, trust me..
Uwe
Old 05-27-2008, 12:08 AM   #33
Westfalia
Westfalia's Avatar
Evergreen , Colorado
Images: 35
Kevin, my 27FB had exactly three leaks upon delivery, and those would have gone unnoticed had it not been for torrential and driving rain in Arkansas when I picked it up. Fortunately, no others have been found once those were plugged. I'm confident that if you can communicate your leaks to the factory, they will get it fixed. Does the mothership have a way to pressure test the trailer like the SealTech pressure test?
Chris - Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is online now   Reply With Quote
Old 05-27-2008, 08:31 AM   #34
Bambi_Bandit
I spoke to the Airstream tech this AM. They will "shower" it with a device similar to that used in production, but outside. It "dumps a much a gallons per hour for 45 min" and they should see any leaks from it.
They statated that they will do all leak checks after replacing the hail damage panels...
Does Gene at Airstream of AR have a Sealtech pressure tester? Hmmm. If so I may need to stop there on the way home from JC...
Kevin
Kevin & Prim Li
WBCCI # 11809
AIR # 6155
Old 05-27-2008, 08:38 AM   #35
Westfalia
Westfalia's Avatar
Images: 35
Yep, he does.
Old 06-03-2008, 04:28 PM   #36
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I guess we've been lucky. No leaks except one of the storage compartment doors and that only leaks when being towed in the rain. It will be fixed under warranty.
Family of Disney Fanatics
WBCCI# 4821
Old 06-03-2008, 04:48 PM   #37
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
You know if I remember correctly, the leak test occurs prior to any of the add on's. It's done before the roof top hatches, air conditioner, skylights, TV antenna, radio antenna, awning, just to name a few are even done. If you watched that program "Made in America" as the trailer was in the water shower, the inside shot of the ceiling showed that the roof was fully intact with no cuts it in yet.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Could I have hit the Jackpot Ganglin Off Topic Forum 26 12-30-2007 08:24 PM
Hit by Lightning jlovelady Tow Vehicles 9 07-17-2007 10:45 PM
Be The Hit Of Your Next Rally... S C Streamer Our Community 23 12-16-2006 02:32 PM
Someone Just Hit My As!!! tin can luv Ribs, Skins & Rivets 16 04-28-2004 07:58 AM
How many times have you hit... drboyd Interior Restoration Forum 29 11-30-2003 05:19 PM
test
