Old 05-21-2012, 07:05 PM   #15
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Thanks Phillip. I appreciate the encouraging words. Some of this repair business is sort of like pulling your own molars. As soon as you pull hard enough to make any progress, the pain gets so bad that you have to stop and have a period of recovery! Certainly not for the faint of heart!
Although, I will have to say that once you figure out how you're going to approach the repairs and formulate a plan, everything gets much easier. I'm not nearly through yet, but I'm through a lot of the worst. Doing the prep work for each phase is harder than doing the actual repair.
Steve
Steve Bryant is offline   Reply With Quote
Old 05-21-2012, 11:23 PM   #16
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
Originally Posted by Steve Bryant View Post
Vivian,
About 70% of the problems that I'm having are due to the fact that the trailer was improperly repaired. There are still some design and construction quality issues that have caused problems. But these design and construction issues are not nearly so serious as the improper repair.
Thanks, Steve. I think ours is OK because the corner with the slight buckle is at the head of a twin bed, and I have pulled up the mattress and supporting plywood sheet several times looking at the storage space under there. I think I would have noticed darkened, damaged, or watermarked plywood subflooring in that corner. At least I hope I would have. It's too heavy to do it by myself, so I'll have to wait until I can get my husband involved. Still a scary thought, though. Hope your repairs are going well.
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Old 05-22-2012, 05:24 PM   #17
1991 34' Limited
Wichita , Kansas
Vivian,
When you do get around to further investigation, you might want to stick an icepick into the wood sub-floor in several places. Assuming that you have carpet, you can stick the icepick right through the carpet and pad and it should not show at all. You need to stick the icepick into several areas so that you have a reference since the icepick may penetrate the subfloor (plywood/oriented strand board) to some degree and still be sound and intact.
Regards,
Steve
wiring? Univolt to Converter '74 Tradewind batt Batteries, Univolts, Converters & Inverters 31 05-10-2014 11:06 AM
Where to add additional batteries demondeacon3 Batteries, Univolts, Converters & Inverters 32 10-23-2012 10:11 PM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
filling cracks and bolt indents goshawks00 Floor Finishes 8 03-09-2012 08:31 AM
Full timing and the eternal toilet question... racer155 Full-Timing 20 03-03-2012 06:33 PM
