Old 02-04-2014, 07:49 PM   #1
Cruisette
1951 15' Cruisette
San Francisco , California
Correct aluminum for a Cruisette?
I'm in the process of restoring this 1951 Cruisette and am planning a full body-off restoration. One body panel that needs repair is the driver side flat panel above the wheel. There is a 2" tear in the aluminum and some denting, probably from a prior flat tire.
1) Does anyone know the right kind of aluminum panel with Alclad to use on a '51 Cruisette, and where I can buy this?
2) Would you recommend replacing the entire panel (rather large), or "patching" a piece the width of the original body panel that is about a foot tall to replace the damaged portion along the bottom?
3) Seeing as I am doing a full body-off restoration, do you have thoughts on what the right time is to perform this replacement? I can think of either (i) after I strip the interior but before I remove the body from the frame, or (ii) after I re-join body and frame but before I replace interior panels. Either way, I am planning on buck riveting.
I plan on polishing the entire trailer as a final step. Appreciate your thoughts!
Thanks.
cruisette51 is offline   Reply With Quote
Old 02-05-2014, 12:27 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
2024 T3 .032 alclad
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 02-05-2014, 02:53 AM   #3
Cruisette
1951 15' Cruisette
Awesome -- thanks. Looks like they sell some at Vintage Trailer Supply, although the biggest size they sell is 48" x 24", which isn't quite large enough for a one-for-one replacement.
Old 02-05-2014, 04:47 AM   #4
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
There's tons of places for sheets stock, airports.com offers up to 32' lengths IIRC. With regard to when to replace I'd replace it after the shell is let back down onto the chassis. Get everything cleco'd back in place then remove and replace that skin.
truckasaurus is offline   Reply With Quote
Old 02-05-2014, 06:42 AM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
I think you mean Airparts.com Another source is Aircraftspruce.com & from my experience they are a bit cheaper.
Colin
Colin H is offline   Reply With Quote
Old 02-05-2014, 09:56 AM   #6
Cruisette
1951 15' Cruisette
aircraftspruce.com is perfect -- thanks for the suggestions!
Old 02-05-2014, 02:00 PM   #7
1960 33' Custom
Thanks Colin, if anyone finds 040" in longer than 12' I'm all ears..
Old 02-05-2014, 03:16 PM   #8
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Good luck, I ordered a huge piece for an aircraft skin years ago, I think was about 6' wide and must have been 20 to 24' long. they had to special order it right from the mill and it took forever to get it and obscenely expensive.
I asked my buyer here at work and 12' was the longest he has ever purchased. I think you can get .032 from Airparts pretty long but as I've never ordered any from them, I wouldn't know how long.
Old 02-05-2014, 03:18 PM   #9
1960 33' Custom
Ah yes in .032" they'll even roll it and UPS it in a carton up to 32' so maybe I'll have to just add some stringers to get that perfect skin.
Cruisette :: 1951 Airstream Cruisette cruisette51 Airstream Registry Discussions 0 01-26-2014 02:13 PM
Silicone caulk on aluminum edglenn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 43 12-21-2012 07:48 PM
Aluminum expansion and contraction Rileybear Ribs, Skins & Rivets 16 07-05-2011 05:46 AM
Aluminum desk top worksology Cabinets, Counter Tops & Furnishings 33 06-30-2011 05:47 AM
Husband sent me this Cruisette for sale on eBay n8andm Airstreams on eBay 0 05-25-2011 12:54 PM
