Old 07-18-2014, 04:24 PM   #1
1973 31' Sovereign
Milton , Delaware
Corner Skin Removel !!&%$#@*!!
OK, Removed Banana wrap, Belt strap, and all the rivets! Positive. Can slide a knife edge between all mating skins except under the wing window.
Here's a pic of the damaged panel before removal efforts.
Are there rivets under the wing window frame?
I can't get the skin to budge??
Please help.
Richard
tartansailor is offline   Reply With Quote
Old 07-18-2014, 05:49 PM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
I just went out and looked at our '73. The bottom row of rivets holding in that window frame are riveted into that panel. There's at least one rivet wedged between the window frame and the outer skin (sort of partially covered by the window frame). My guess (just a guess) is that there are rivets under the window frame as well. I found lots of rivets in odd places when the interior skins were out.
Are you planning on removing the interior skins and buck new rivets back in? With those panels removed you should be able to see all the exterior bucked rivets (I know, obvious, right?).
www.nesa.org
Air No. 6427
Old 07-18-2014, 06:31 PM   #3
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Okay I have missed something! I see the dent but it can be removed without removing the panel so is there a rip or tear not in the picture? With that type of dent you may have two barely noticeable creases in on either side of the dent and when you remove the dent you can add a shell rib to reinforce the repair. If you must remove the panel then all of the buck rivets on the panel must come out and any of the hidden rivets (bottom and top edges) most common places if there are any.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-20-2014, 02:21 PM   #4
1973 31' Sovereign
Milton , Delaware
Jim & Susan and Cliff,
Sincere thanks for the replies. Got it off! The wing window and a darn hidden rivet in the upper left corner under 2 panels, had to be removed. The latter took the better part of a day to access. The plan is to ask Colin to English wheel that and 2 banana wraps. On re-installation, I feel bucking is the only way to go.
Richard
Rjp103 is offline   Reply With Quote
Toilet Removel Help Needed Bmccaulley Sinks, Showers & Toilets 3 03-03-2012 10:12 AM
Window removel. elzavb Rock Guards, Segment & Window Protectors 1 08-18-2010 04:26 AM
How to clean and paint wood walls AFTER wallpaper removel whitefawn Upholstery, Blinds, Walls & Interior Finishes 2 07-21-2010 07:52 PM
corner radius skin Naturescalin Belly Pans & Banana Wraps 9 11-03-2004 04:03 PM
Dent removel - two methods j54mark Ribs, Skins & Rivets 13 04-18-2003 11:52 AM
