Old 07-10-2014, 12:17 PM   #1
1973 31' Sovereign
Milton , Delaware
Corner Skin Removal
I wish to remove the curb side front lower curved skin in order to have it "English Wheeled" I'm worried that I may do more harm in removing than what's already there.
Are the mating skins glues together? and if so, how to separate?.
Any suggestions? What to look out for?
Thanks in advance.
Richard
tartansailor is offline   Reply With Quote
Old 07-11-2014, 04:42 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Skins aren't exactly glued together, but there is bound to be plenty of flexible sealant on the inside which will seem to be gluing it together. Judicious use of a putty knife to separate things is all that is needed.
One potential stumbling block is just in drilling out the rivets. A rivet removal tool is handy, or just careful use of a center punch and sharp (short) drill bits. You just want to avoid overly enlarging the rivet holes and slipping off the head.
Old 07-11-2014, 06:25 PM   #3
Central , Mississippi
I have done this on a '77 and I'm about to do it on a pal's '75.
It's one of the easier things that really make a trailer look better. It's all pop rivets, some are underneath, some are behind the lower belt line.
Using a wheel and not a hammer is the perfect way to go. I took an old skateboard wheel that was worn round on the edges and mounted on a piece of wood for a handle. Laying the wrap on a cushion allowed me to roll out the dents from the inside. The aluminum is not alclad so it's possible to sand the outer side smooth for the last few imperfections.
Go For It!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-11-2014, 07:36 PM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
What no pictures what are you using an English wheel on?
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-11-2014, 10:41 PM   #5
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
FYI:
I like to use a High temp heat gun at seams, YES the aluminum expands causing the two skins to separate, don't worry the skin will cool back to original shape...
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Replacement of Airstream rear corner skin arkile Ribs, Skins & Rivets 2 03-07-2014 07:48 AM
Recommend shop to replace a rear corner skin on W Coast? rebelhoop Interior Restoration Forum 4 10-21-2012 05:34 PM
Back corner skin repair? gochisox2005 Member Introductions 16 03-06-2008 04:42 PM
replacing lower corner skin wayne.yl Belly Pans & Banana Wraps 13 05-20-2007 01:57 PM
corner radius skin Naturescalin Belly Pans & Banana Wraps 9 11-03-2004 04:03 PM
