Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-25-2018, 09:52 AM   #1
1976 31' Sovereign
RICHLAND HILLS , Texas
Corner Panel Replacement or Repair
The lower rear corner of my 1976 Airstream Sov 31 ft has some damage and when removed the rub rail I noticed that a patch had been added, only very poorly done. There is no butyl tape, only a slight bit of silicone and very few rivets actually holding the patch on. Hence the subfloor being gone in the rear. I need to repair this and at first since I was not able to find a pre made formed piece on any airstream part store, I assumed a flat piece of sheet would work just find. Once I removed it tho, it appears to have been a pre formed piece. I am wondering if anyone has encountered this? Thinking my options are to either hammer out the dents and patch it better or get a new piece and see if a hot rod rests shop with an english wheel can make me something. Unless anyone knows if I can get this piece pre made? Thank you!
<a data-flickr-embed="true" href="https://www.flickr.com/photos/160354565@N03/30392718858/in/dateposted-public/" title="IMG_1563"><img src="https://farm2.staticflickr.com/1888/30392718858_4b67956972_k.jpg" width="1536" height="2048" alt="IMG_1563"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/160354565@N03/44259114761/in/dateposted-public/" title="IMG_1565"><img src="https://farm2.staticflickr.com/1843/44259114761_8dd2928d7b_k.jpg" width="2048" height="1536" alt="IMG_1565"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
IanSeekFirst is offline   Reply With Quote
Old 08-25-2018, 11:34 AM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
Ian, I approved your thread, but let's turn this into a learning experience. If you want to post photos from Flickr, then use the "BB Code" that Flickr offers for sharing. Here's a share of my own with the BB code:
southoregoncoast2 by Lynn Eubank, on Flickr
Lynn
ACI Big Red Number 21043
Old 08-27-2018, 04:35 AM   #3
1976 31' Sovereign
Thanks! I appreciate the info!
So heres the images embedded correctly!
IMG_1563 by Ian Miller, on Flickr
IMG_1565 by Ian Miller, on Flickr
Removing exterior corner panel REDSLED88 Ribs, Skins & Rivets 23 02-19-2015 04:09 PM
Bent front corner panel Popcornkid Member Introductions 4 11-17-2012 08:54 AM
Help! Dealer put 4" scratch in lft mid corner panel ncbambi General Repair Forum 16 08-05-2009 12:54 PM
1975 25' Tradewind Lower Corner panel and rock dings Pepsi Ribs, Skins & Rivets 4 02-08-2009 10:48 AM
Rear corner body panel woes sladew Ribs, Skins & Rivets 50 06-21-2006 10:42 AM
