Old 01-11-2012, 05:35 PM   #1
Lothlorian's Avatar
Loganville , Georgia
CNC machine art work for exterior
I am looking to have a piece of aluminum cut into art work. This would be round and cover a hole from an old antenna on my 1960 airstream. I would like to have it in a 3D format. A round patch with an cut out piece of art attached to the patch. I saw a few trailers with these when I was checking out some Vintage trailers. Where can I get this work done and how much would it cost?
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 01-11-2012, 06:25 PM   #2
1981 31' Excella II
New Market , Alabama
I would expect a few hundred dollars on up, for a, one of, 3D engraving. It would not cost you much more to have 100 of them made as one. There maybe some folks online that will do it but I expect a local machine shop could do it. If you had a 3D model of the part it would lower your costs considerably. Look in the phone book for CNC machining or CNC engraving. First thing is you need a design. Then you need a 3D model of that design. Then it has to be converted to something that a CNC mill can understand.
Perry
Old 01-11-2012, 07:05 PM   #3
Lothlorian's Avatar
Thanks very much for the info. I will do my research.
Brian
Brian & Adrienne
Old 01-12-2012, 07:43 AM   #4
Lothlorian's Avatar
I am bringing this back to the portal. I want to put an artistic patch over the old antenna hole for my 1960 airstream. I may just go buy a wind chime that has metal animals for chimes and take one and rivet it to a round aluminum patch. Any suggestions?
Brian
Brian & Adrienne
Warranty work on new 2012 25fb Flying Cloud danlehosky General Repair Forum 8 02-04-2012 08:55 PM
Just a little art work xo1rider Off Topic Forum 4 12-21-2011 10:07 AM
Airstream Fine Art! R2DTube Off Topic Forum 1 12-01-2011 06:19 AM
Should interior lights work with no battery but with Tow Vehicle connected bocotim Electrical - Systems, Generators, Batteries & Solar 12 11-03-2011 10:06 AM
NOSE ART for the AirStream Intrepid Off Topic Forum 30 08-09-2011 08:47 AM
