Old 11-20-2009, 08:12 AM   #15
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You dab some Vulkem into the hole before you set your rivet in it. No big deal.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 11-23-2009, 09:36 AM   #16
WILDRTEXAS's Avatar
1970 27' Overlander
ARLINGTON , TEXAS
Images: 31
Send a message via Skype™ to WILDRTEXAS
Hi Vernon,
Do you have these rivets for sale?
Thanks, Cynthia
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
WILDRTEXAS is offline   Reply With Quote
Old 11-23-2009, 10:12 AM   #17
Kevin245's Avatar
Originally Posted by WILDRTEXAS View Post
Hi Vernon,
Thanks, Cynthia
Hi Cynthia,
You can purchase closed end rivets at most local Fastenal locations, your local industrial supply store, or you can order them (what I do) at either:
www.fastenal.com
www.mcmastercarr.com
Regards,
Kevin
Eleanor Roosevelt
Old 05-27-2010, 12:56 PM   #18
1981 31' Excella II
Longview , Texas
Images: 14
I see this is an old thread - hopefully someone will reply. I'm in the process of remodeling and 'sealing' my '81 Excella. I'm replacing the brittle and broken vinyl belt-line and rub-rail inserts. I also have a lot of the inside skin removed from re-wiring and replacing insulation. While I have the inside skin and vinyl rail inserts removed, I might as well seal all of the rivets. Replacing them all with closed end rivets would be a chore but might be worth it as this is my first AS and I'd like to keep it for a while without having to 'gut' it again.
I'm wondering what size rivets to use for the rub-rail. I think they are 1/8" but I'm not sure what grip range to get. Is there one size that I can use for all inner skin/etc and rub rail inserts?
While I'm askin - what size are used to fasten the belly skin to the frame - 3/16"? Not sure on grip range for these either.
Thanks in advance for any thoughts and info! I really appreciate it.
Michael
boo_n_sue is offline   Reply With Quote
Old 05-29-2010, 10:04 PM   #19
Michael
You can use #48 pop rivets for the rub rails. The grip range is not critical, but using rivets that are longer than actually neede, does no harm, nor does it cause any problems.
The best rivets to use for the underbelly are # 68 "large head" pop rivets.
The larger head pays many dividends in time.
Airstream or Pop-up? Jezibels Buyer Guidelines 50 08-13-2009 06:21 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
What's with the pop up ads?? Ultradog Off Topic Forum 15 04-13-2007 08:22 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
