Old 04-30-2015, 01:14 PM   #1
rowdyATX's Avatar
1956 26' Cruiser/Overlander
1961 28' Ambassador
Clecos, correct size
What size clecos (including grip range) should be used for repair/restore? And can you recommend a certain set of pliers, and other tools I'll need for this part of the restore?
Also, if you can include the name / contact of the supplier, that would be helpful.
rowdyATX is offline   Reply With Quote
Old 04-30-2015, 01:34 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
You can get a good "starter kit" for buck riveting from Vintage Trailer Supply (or you can order the pieces ala-carte as well). The kit has a buck riveting gun a rivet cutter, 25 or so clecos for 5/32" riveting, a bucking bar, etc.. Depending on how much riveting you intend to do, you may want to order at least 50 of the 5/32" clecos, and at least 25 of the 1/8" clecos for holding things in place that will be pop-riveted with 1/8" rivets.
Airstream Buck Riveting Kit
You can also get tools from The Yard store inc., Aircraft Spruce, and Airparts, Inc., if you want to do some comparison shopping and hunt around. I bought the VTS kit and have been very satisfied with it.
good luck!
Old 05-22-2015, 07:17 AM   #3
rowdyATX's Avatar
1961 28' Ambassador
Does this look like an adequate kit to get?
http://www.yardstore.com/browse.cfm/4,3718.html
Old 05-22-2015, 09:22 AM   #4
Belegedhel's Avatar
Houston , Texas
Overkill. I would guess there is at least $150 worth of tools that you really won't need on an Airstream.
You really only need two sizes of clecos (1/8" and 5/32"), You will only need one (maybe two) anvils for the rivet gun, sized for the heads of of your 5/32" bucked rivets (though there are some smaller bucked rivets on some of the window frames). If you get fancy and do some flat, countersunk rivets, then a flat anvil is also needed. For bucking bars, a good general purpose one will fit 95% of your needs. I needed one other particularly skinny one for some tight work, but that was it.
good luck!
Clecos grip range rowdyATX General Repair Forum 2 04-30-2015 03:05 PM
How many clecos? bass-o-matic General Repair Forum 6 06-20-2014 06:29 PM
How do I clean Vulkem from Clecos? rumrunner Ribs, Skins & Rivets 5 08-05-2013 07:50 AM
Clecos - will I wish I had 'em? Old Nuke General Repair Forum 24 03-11-2009 05:33 AM
What is the correct bearing size for a 1962 toastie Axles 16 11-02-2006 10:49 PM
