Old 03-29-2011, 01:47 PM   #1
hotstuff's Avatar
1969 27' Overlander
Bastrop , Texas
Caulk behind replacement rivets?
WHen you are replacing exterior rivets, do you put caulk in the holes? THanks
hotstuff is offline   Reply With Quote
Old 03-29-2011, 04:46 PM   #2
x
XXXX , XXXX
Yes and if you have the interior skins off they also get sealed from inside as well.
wasagachris is offline   Reply With Quote
Old 03-29-2011, 05:39 PM   #3
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Maybe check around with restorers before you use "caulking". I don't have personal experience with this, but I know there are other products like "Vulkem" that are designed to be compatable with aluminum.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-29-2011, 05:48 PM   #4
x
XXXX , XXXX
I was assuming he meant Vulkem. Good catch Kevin.
Old 03-29-2011, 06:28 PM   #5
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Definitely use Vulkem an not caulking. I have been told once caulking is used on aluminum nothing after it's removed will bond. Good luck.
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 05-31-2011, 08:34 AM   #6
hotstuff's Avatar
1969 27' Overlander
Bastrop , Texas
Thanks for the info. My question was a little premature. I am finally starting to pull off the windows and patch the roof. I started a thread to document my struggles. My 69 overlander journey.
Old 05-31-2011, 08:37 AM   #7
soldiermedic's Avatar
Florissant , USA
Don't use silicone sealants. The best advice is to use polyurathane base sealants. Sikaflex, and Trempro (Vulkem) are great. Many people also use Alcoa gutter seal or Acryl-R from the Airstream store.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 05-31-2011, 08:58 AM   #8
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Depends on the kind of rivets you are using.
Bucked Rivets - No, not on each rivet. We do use Vulkem between the overlapped edges of the panels or accessories though and enough squeezes into the hole when the rivet is "bucked". The solid shank rivet compresses and fills the hole pretty completely - enough Vulkem oozes into the hole around the rivet from between the panels or drip caps, etc..
Olympic Rivets - Yes, we dip each rivet in Vulkem prior to sticking it in the hole and pulling it in addition to the Vulkem between the overlapped edges. We then clean off the excess around each rivet with a rag & mineral spirits BEFORE it drys. We NEVER use the gasketed Olympics...the little washers are supposed to help with leaks, which they might do for a short while, but they eventually deteriorate and fail then leave a gap for water to get in.
Pop Rivets - No. These are only used inside the trailer, there shouldn't be a need - the idea is to keep the water out from beween the skins so there it it's sealed on the outside, water shouldn't get inside. The only area I can see an exception is if you are using them inside a shower stall - then yes, you would want to seal them to keep the water from getting into the wall channel space. Water between the skins is the scourage of Airstream owners everywhere - it leads to floor rot.
Shari
Old 06-03-2011, 07:40 AM   #9
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Is there a specific Vulkem I should use on banana wrap?What about the rub rail that covers that seam?Is Vulkem a product I can find locally?I haven't had any luck locally and I'm assuming it's a special order item.
desertair27 is offline   Reply With Quote
Old 06-03-2011, 07:53 AM   #10
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
sikaflex 221 - Google Search
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-03-2011, 08:37 AM   #11
InsideOut's Avatar
1956 22' Safari
Images: 108
Actually, the modern replacement is not called Vulkem any more...it's Trempro. It can be ordered from Vintage Trailer Supply. We use Trempro 635 but the Sikaflex 221 is the same thing - just make sure it's "gray" and not white.
Shari
Old 06-03-2011, 01:20 PM   #12
Thumbs up
Shari
Speaking of all this Sikaflex stuff....
How frustrating is it to go back to a tube you only used about a third of and you can't for the life of Gomer get any more out....
Three daze ago I replaced the Skylight.....When I was done I suffered a euphony and a light went on, grabbed a very course threaded Loooong wood screw shoved it down that rascal's nose, and when I went to use it today I gave that screw a tug and it pulled about two inches of cured Sika right out the end. I started tug'n gently and that stuff just stretched it's way right out.
If it works for you pass it on... If it don't blame Gomer
PFC
"Tahawus"
RLC
John Prine
Old 06-03-2011, 06:19 PM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
We always stick a nail/screw in the tip, then store it in the garage fridge. Seems to help keep it from seizing up as quickly. But even still, it's best to do a bunch of caulking at one time 'cause once it's opened, it doesn't last long. Weird stuff...
Shari
Old 06-03-2011, 07:35 PM   #14
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Wax in the tip when you put it up works ok as well...
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
Need advice on inverter replacement for Paralax Nightwatch Electrical - Systems, Generators, Batteries & Solar 1 02-13-2011 01:04 PM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
