Old 10-17-2007, 09:49 PM   #1
1970 27' Overlander
Bozeman , Montana
Buying an AIRSTREAM w/ Body Damage?
Hi - I'm looking into buying an Airstream but am not sure about body damage. Can someone take a look at this and give me their opinion about the possibility of repair on damage like this? Otherwise, this airstream is in pretty good shape and going for $3500. THNX!
ID:	47572   Click image for larger version
tendegrees is offline   Reply With Quote
Old 10-17-2007, 10:33 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Do you know how this damage happened?
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 10-17-2007, 10:57 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You need to find out how it happened. The wheel well dagage looks like a tire came off or shreded. The other who knows. It is expensive to replace those panels. get an estimate first if you are thining about repairing.
Michelle TAC MT-0
Sarah, Snowball
Old 10-17-2007, 11:47 PM   #4
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
By all means ~ get an estimate! And follow up on Janet's suggestion...find out how it happened! Make sure everything under the floor (in the you-can't-see-it area) is okay! Compare the same model/make with others of similar years for price without damage.
Good luck.
Mrs. NorCal Bambi (traveling in S Tardis ~ from the Great State of Jefferson)
CaddyGrn is offline   Reply With Quote
Old 10-18-2007, 04:19 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Fixing it right will be quite a bit of money. It depends on how fussy you are and what you intend to use the trailer for. You could use aluminum duct tape and make it waterproof as it stands for no money and just use it as is. Not pretty but usable. Fixing it right would likely run over $1,000.
Old 10-18-2007, 05:55 AM   #6
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
With that amount of damage I belive panel replacement would exceed $3000.
I also belive a wheel came off.
jkcru is offline   Reply With Quote
Old 10-18-2007, 07:48 AM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
With all the damage, and the fact it is all on the right side, and down low, starting at the front, it looks like the trailer went into the ditch.
Old 10-18-2007, 08:21 AM   #8
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The front curbside wheel is missing the insert that covers the hub. This might be a clue. The wheel may have left the trailer and the cover was damaged or never seen again...
Richard
Old 10-18-2007, 09:30 AM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I agree, looks like it went into a ditch ~
If it were me, I'd get an estimate on the repair and add that to the cost of the trailer - then decide if the total cost is "fair" and still "a really good deal". I defiantely would not leave it as is - way too much potential for water getting into the floor and causing bigger problems with rot & frame rust, especially in the humid south.
Based on the dimples in the first picture, it looks like someone already tried to pull the dent out or "make it better" - to no avail.
What model/year trailer is it? Looks to be pretty "late model" ~ my intial guess is you can do better for less hassle.
Shari
Old 10-18-2007, 09:46 AM   #10
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Looks like the perfect oportunity to keep shopping. There are lots of units out there without the traumatic history that this one seems to have had.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-18-2007, 10:06 AM   #11
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I can easily repair interior and mechanical components and even some body damage problems without issues about weather or usage or costs getting out of hand since I'm doing the work.
The problem with body damage of this nature is that if I want it done quickly, and properly, so I can use the trailer for camping, I have to farm it out and then I'm at the mercy of the repair facility. Some are outstanding and really take care of their clients and others are less committed to service excellence. Finding the right one, in your area, who can take it in and get it done in a time frame that you need, becomes a bunch of work right up front. With this kind of damage I can't help but wonder what else is damaged behind. There's a good chance that there are at least a "few" surprises that will add cost, time to repair, and make your purchase a burden rather than the exciting event it should be.
I'd be taking a pass on this one and continue my search. There's a reason it's a "good deal" up front. There are a lot of outstanding Airstreams for sale and you will find the one that fits your budget and needs.
Good luck with your search.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 10-18-2007, 10:21 AM   #12
urbanfood's Avatar
1956 22' Flying Cloud
Venice , California
what barry said
david
*by asking the above question,
i verify that i have already used
the search feature to the best of my ability...
urbanfood is offline   Reply With Quote
Old 10-18-2007, 10:53 AM   #13
Phoenix , Arizona
This would be my advise also.
I looked at one that showed simillar damage and he had a tire come apart. I went inside, lifted the bunk on that side and I was looking at the ground. There was a 6in hole in the belly.
DesertDog is offline   Reply With Quote
Old 10-19-2007, 10:11 AM   #14
LJH
LJH's Avatar
1985 27' Sovereign
Defiance , Ohio
Keep lookin.
LJH is offline   Reply With Quote
Narrow body/Wide body jcanavera Our Community 11 04-05-2006 01:25 PM
Airstream Body/Repair Shop Kodeman Commercial Listings 21 11-08-2004 09:36 PM
Airstream body damage, SF Bay Area?? nglase General Motorhome Topics 0 09-10-2003 08:07 PM
Body damage repair AccessMaster Airstream Motorhome Forums 0 08-14-2003 11:07 AM
is a 1978 ARGOSY Airstream 28 all aluminum body ? oldvws Our Community 2 12-22-2002 01:46 PM
