Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-20-2011, 05:33 PM   #1
Halimer
2006 25' Classic
New Hyde Park , New York
Buck Rivets or Olympic Rivets
Our AS got hit pretty badly by the 1 Aug 2011 hail storm that struck Long Island. I need all 3 front nose panels and the rear center panel replaced
I realize the factory uses buck riveting when the AS was made. Is there any major disadvantage if Olympic rivets are used?
Mark
halimer is offline   Reply With Quote
Old 09-20-2011, 06:06 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Unless you take the inner skin off, Olympics are your only choice.
Bill
Mark
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 09-20-2011, 06:20 PM   #3
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
Olympics require a bigger hole and are not as strong a fastener as a properly bucked solid rivet. The one main advantage though is you don't need access to the back side of the panel for the olympic......Phil.
pgr32e is offline   Reply With Quote
Old 09-20-2011, 10:28 PM   #4
Halimer
2006 25' Classic
The inner skin(interior) will be taken off.
mark
Old 09-20-2011, 11:27 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Then use buck rivets.
Bill
mark
Old 09-21-2011, 03:20 AM   #6
Baltimore , Maryland
olympic rivets are notorious leakers. Avoid using them for what you plan on doing.
Greasy rivets! tphan Ribs, Skins & Rivets 9 09-04-2011 09:41 AM
'64 -Do I HAVE to drill out the buck rivets? robwok Belly Pans & Banana Wraps 4 06-14-2011 09:35 AM
78 argosy interior rivets argosyman General Interior Topics 2 05-17-2011 11:49 AM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
